ā02-16-2012 08:36 AM - edited ā07-03-2021 09:36 PM
I have some problem with 802.11A radio is enabled but the detaild status is still display software status is disabled and hardware status is down. I checked the settings on Enable Radio is checked on enable. I can't get any radio accross. Any ideas whereelse I can check to get this working?
speed basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
power local 18 <<<<<<<<<<< I can't input this line from the command line. I assume that the bridge is taking the MAX setting. Please helps.
power client 18
packet retries 128
station-role non-root
rts threshold 4000
rts retries 128
concatenation
beacon period 20
infrastructure-client
I am really appreciated that everyone can give me some helps.
CD
ā02-16-2012 06:37 PM
you're going to need to post the rest of the config.
ā02-17-2012 11:17 AM
Hi Jeff
I copy the configuration of the bridge. This is a new bridge that I setup as a role non-root bridge. with the new default configuration, as soon as I changed the role to non-root bridge, the 802.11A interface is down and disabled. Is it normal operation and how do I enable it back? any helps I am really appreciated that
version 12.4
no service pad
service password-encryption
hostname NonRootBridge1
no logging console
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
resource policy
clock timezone MST -7
clock save interval 24
ip subnet-zero
ip domain name NonRootBridge1
dot11 activity-timeout bridge default 10000
dot11 ssid LabTest
vlan 51
authentication open
infrastructure-ssid
dot11 network-map
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid LabTest
packet retries 128
station-role non-root bridge
rts threshold 4000
rts retries 128
cca 90
concatenation
beacon period 20
interface Dot11Radio0.51
encapsulation dot1Q 51 native
no ip route-cache
no snmp trap link-status
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
interface FastEthernet0.51
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.0.10 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line vty 0 4
sntp server 192.168.0.50
sntp broadcast client
end
ā02-17-2012 11:21 AM
What does the other 1440 config look like? Is it set as a root? Does it have authentication enabled? Same VLAN? Same SSID?
ā02-17-2012 11:26 AM
another 1440 configure is look the same accept it set as the root. Both of these on the same VLAN 51. and same SSID LabTest. The authentication is also enabled.
ā02-17-2012 11:28 AM
On the non-root you have āauthentication openā on dot11.51 Is that the same on the root bridge?
ā02-17-2012 11:51 AM
On the root bridge, the authentication open is the same in dot11.51
Below is the configuration for root bridge.
version 12.4
no service pad
service timestamps log datetime msec localtime show-timezone
hostname RootBridge1
logging console informational
logging monitor informational
aaa new-model
resource policy
ip subnet-zero
ip domain name RootBridge1
no dot11 igmp snooping-helper
dot11 ssid LabTest
vlan 51
authentication open
infrastructure-ssid
dot11 network-map
bridge irb
no ip address
no ip route-cache
logging event subif-link-status
ssid LabTest
power local 23
packet retries 128
station-role root bridge
rts threshold 4000
rts retries 128
cca 90
concatenation
distance 10
beacon period 20
encapsulation dot1Q 31 native
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
hold-queue 80 in
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.0.20 255.255.255.0
no ip route-cache
no ip http server
ip http authentication aaa
logging history size 100
logging history informational
bridge 1 route ip
line con 0
access-class 111 in
line vty 0 4
access-class 111 in
line vty 5 15
access-class 111 in
end
ā02-17-2012 11:57 AM
You have a different vlan on the root than on the non-root.
Jeff Van Houten
Vice President &
Chief Technology Officer
First Bank and Trust
909 Poydras St.
Suite 3300
New Orleans, LA 70112
www.fbtonline.com<>>
"Your Goals Come First"
ā02-17-2012 12:08 PM
I made changes now.
Does it makes the interface goes down?
ā02-17-2012 12:10 PM
The 1440s are a bridge. The bridge is like plugging two cables into a hub. There should be no difference in the vlans on either side of the bridge.
ā02-17-2012 12:16 PM
I am using the power injector AIR-PWRINJ-BLR1.
How about with the new default configuration, I changed the role from install automatic to non-root bridge, the 802.11A goes down (hardware = down and software = disable)? Is this normal operation? How do I enable it back?
I am really appreciated all your helps
