04-27-2015 05:21 AM - edited 07-05-2021 03:03 AM
Hi, so I have bought 6 1700 APs and one 2504 WLC. Three of my APs have connected fine to the WLC and are registered. 3 will not!
The WLC is running software: 8.0.115.0
Please help
Here is a debug I have managed to grab:
(Cisco Controller) debug>capwap events enable
(Cisco Controller) debug>*spamApTask0: Apr 27 21:21:58.414: f0:7f:06:09:e3:b4 Received LWAPP DISCOVERY REQUEST to ff:ff:ff:ff:ff:ff on port '1'
*spamApTask0: Apr 27 21:21:58.414: f0:7f:06:09:e3:b4 Discarding discovery request in LWAPP from AP supporting CAPWAP
*spamApTask2: Apr 27 21:22:08.413: f0:7f:06:09:e3:b4 Discovery Request from 192.168.10.230:40508
*spamApTask2: Apr 27 21:22:08.413: f0:7f:06:09:e3:b4 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 25, joined Aps =0
*spamApTask2: Apr 27 21:22:08.413: apModel: AIR-CAP1702I-Z-K9
*spamApTask2: Apr 27 21:22:08.413: apType = 45 apModel: AIR-CAP1702I-Z-K9
*spamApTask2: Apr 27 21:22:08.413: f0:7f:06:09:e3:b4 Discovery Response sent to 192.168.10.230 port 40508
*spamApTask2: Apr 27 21:22:08.413: f0:7f:06:09:e3:b4 Discovery Response sent to 192.168.10.230:40508
*spamApTask2: Apr 27 21:22:08.414: f0:7f:06:09:e3:b4 Discovery Request from 192.168.10.230:40508
*spamApTask2: Apr 27 21:22:08.414: f0:7f:06:09:e3:b4 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 25, joined Aps =0
*spamApTask2: Apr 27 21:22:08.414: apModel: AIR-CAP1702I-Z-K9
*spamApTask2: Apr 27 21:22:08.414: apType = 45 apModel: AIR-CAP1702I-Z-K9
*spamApTask2: Apr 27 21:22:08.415: f0:7f:06:09:e3:b4 Discovery Response sent to 192.168.10.230 port 40508
*spamApTask2: Apr 27 21:22:08.415: f0:7f:06:09:e3:b4 Discovery Response sent to 192.168.10.230:40508
(Cisco Controller) debug>pm pki enable
(Cisco Controller) debug>*spamApTask2: Apr 27 21:22:18.411: f0:7f:06:09:e3:b4 DTLS connection not found, creating new connection for 192:168:10:230 (40508) 192:168:10:4 (5246)
*spamApTask0: Apr 27 21:24:28.897: f0:7f:06:09:e3:b4 Received LWAPP DISCOVERY REQUEST to ff:ff:ff:ff:ff:ff on port '1'
*spamApTask0: Apr 27 21:24:28.897: f0:7f:06:09:e3:b4 Discarding discovery request in LWAPP from AP supporting CAPWAP
*spamApTask7: Apr 27 21:24:39.895: f0:7f:06:09:e3:b4 Discovery Request from 192.168.10.235:40508
*spamApTask7: Apr 27 21:24:39.895: f0:7f:06:09:e3:b4 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 25, joined Aps =0
*spamApTask7: Apr 27 21:24:39.895: apModel: AIR-CAP1702I-Z-K9
*spamApTask7: Apr 27 21:24:39.895: apType = 45 apModel: AIR-CAP1702I-Z-K9
*spamApTask7: Apr 27 21:24:39.895: f0:7f:06:09:e3:b4 Discovery Response sent to 192.168.10.235 port 40508
*spamApTask7: Apr 27 21:24:39.895: f0:7f:06:09:e3:b4 Discovery Response sent to 192.168.10.235:40508
*spamApTask7: Apr 27 21:24:39.896: f0:7f:06:09:e3:b4 Discovery Request from 192.168.10.235:40508
*spamApTask7: Apr 27 21:24:39.896: f0:7f:06:09:e3:b4 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 25, joined Aps =0
*spamApTask7: Apr 27 21:24:39.896: apModel: AIR-CAP1702I-Z-K9
*spamApTask7: Apr 27 21:24:39.896: apType = 45 apModel: AIR-CAP1702I-Z-K9
*spamApTask7: Apr 27 21:24:39.896: f0:7f:06:09:e3:b4 Discovery Response sent to 192.168.10.235 port 40508
*spamApTask7: Apr 27 21:24:39.896: f0:7f:06:09:e3:b4 Discovery Response sent to 192.168.10.235:40508
*spamApTask7: Apr 27 21:24:50.893: f0:7f:06:09:e3:b4 DTLS connection not found, creating new connection for 192:168:10:235 (40508) 192:168:10:4 (5246)
*spamApTask7: Apr 27 21:24:50.894: sshpmGetCID: called to evaluate <cscoSha2IdCert>
*spamApTask7: Apr 27 21:24:50.894: sshpmGetCID: comparing to row 5, ID cert >bsnSslWebauthCert<
*spamApTask7: Apr 27 21:24:50.894: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebadminCert<
*spamApTask7: Apr 27 21:24:50.894: sshpmGetCID: comparing to row 3, ID cert >cscoSha2IdCert<
*spamApTask7: Apr 27 21:24:50.894: sshpmGetDERIDCert: Using SHA2 Id cert on WLC
*spamApTask7: Apr 27 21:24:50.894: sshpmGetCertFromCID: called to get cert for CID 193d632b
*spamApTask7: Apr 27 21:24:50.894: sshpmGetCertFromCID: comparing to row 5, certname >bsnSslWebauthCert<
*spamApTask7: Apr 27 21:24:50.894: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebadminCert<
*spamApTask7: Apr 27 21:24:50.894: sshpmGetCertFromCID: comparing to row 3, certname >cscoSha2IdCert<
*spamApTask7: Apr 27 21:24:50.894: sshpmGetDERIDCertPrivateKey: Using SHA2 Id cert Private Keys on WLC
*spamApTask7: Apr 27 21:24:50.894: sshpmGetSshPrivateKeyFromCID: called to get key for CID 193d632b
*spamApTask7: Apr 27 21:24:50.894: sshpmGetSshPrivateKeyFromCID: comparing to row 0, certname >bsnOldDefaultIdCert<
*spamApTask7: Apr 27 21:24:50.894: sshpmGetSshPrivateKeyFromCID: comparing to row 1, certname >bsnDefaultIdCert<
*spamApTask7: Apr 27 21:24:50.894: sshpmGetSshPrivateKeyFromCID: comparing to row 2, certname >cscoDefaultIdCert<
*spamApTask7: Apr 27 21:24:50.894: sshpmGetSshPrivateKeyFromCID: comparing to row 3, certname >cscoSha2IdCert<
*spamApTask7: Apr 27 21:24:50.894: sshpmGetSshPrivateKeyFromCID: match in row 3
*emWeb: Apr 27 21:25:04.437: sshpmUpdateCertConfig: called.
*emWeb: Apr 27 21:25:04.437: sshpmUpdateCertConfig: writing out credential index.
*sshpmLscTask: Apr 27 21:25:06.446: sshpmLscTask: LSC Task received a message 4
*spamApTask2: Apr 27 21:25:08.446: f0:7f:06:09:e3:b4 DTLS Handshake Timeout server (192.168.10.4:5246), client (192.168.10.230:40508)
*spamApTask2: Apr 27 21:25:08.447: acDtlsPlumbControlPlaneKeys: lrad:192.168.10.230(40508) mwar:192.168.10.4(5246)
*spamApTask2: Apr 27 21:25:08.450: f0:7f:06:09:e3:b4 DTLS connection closed event receivedserver (192.168.10.4/5246) client (192.168.10.230/40508)
*spamApTask2: Apr 27 21:25:08.450: f0:7f:06:09:e3:b4 No entry exists for AP (192.168.10.230/40508)
*spamApTask2: Apr 27 21:25:08.450: f0:7f:06:09:e3:b4 No AP entry exist in temporary database for 192.168.10.230:40508
04-27-2015 05:44 AM
Maybe the APs have the wrong Regulatory Domain.
Can you post the complete output to the following commands:
1. WLC: sh sysinfo;
2. WLC: sh time; and
3. AP: sh version.
04-27-2015 05:49 AM
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.0.115.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
Build Type....................................... DATA + WPS
System Name...................................... ipswireless
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.10.4
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 0 days 1 hrs 21 mins 46 secs
System Timezone Location......................... (GMT+10:00) Sydney, Melbourne, Canberra
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... AU - Australia
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +31 C
External Temperature............................. +34 C
Fan Status....................................... 3200 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 68:9C:E2:BE:C7:C0
Maximum number of APs supported.................. 75
System Nas-Id.................................... ipswireless
WLC MIC Certificate Types........................ SHA1/SHA2
04-27-2015 05:52 AM
(Cisco Controller) >show time
Time............................................. Mon Apr 27 22:50:18 2015
Timezone delta................................... 0:0
Timezone location................................ (GMT+10:00) Sydney, Melbourne, Canberra
NTP Servers
NTP Polling Interval......................... 86400
Index NTP Key Index NTP Server NTP Msg Auth Status
1 0 192.168.10.2 AUTH DISABLED
04-27-2015 06:00 AM
Hi i need help getting the 'sh version' for the AP...
I can find the temp IP address of the AP by looking in the logs on the WLC. When i SSH into the AP i need to login so i try cisco/cisco. This does not work...access denied.
How do i get this info for you?
04-27-2015 10:25 PM
Ok, this is telling me your controller is configured for Australia. This means your AP should have the regulatory domain of "-N", "-Z" or "-UX". If the AP does NOT have the following regulatory domain, then this is the cause as to why your AP ain't joining your controller.
If you cannot physically access the AP, then check your delivery receipt.
04-28-2015 12:31 AM
all six APs are "-Z" units...
04-28-2015 01:17 AM
Hmmmm ... The only culprit left is that the APs came with MESH IOS.
04-28-2015 02:18 AM
ok cool. how do I fix that?
04-28-2015 03:30 AM
04-28-2015 05:43 AM
Hi I have followed these instructions exactly...
No APs are showing up :(
thank you for your help so far. any other ideas?
04-28-2015 03:17 PM
Console into the AP and reboot the AP. I want to see what it's doing.
05-12-2015 05:11 AM
here is the output from a telnet session of the ap booting:
n6▒S+F{V▒[6▒▒؍
▒+▒s#▒{
6{▒s▒▒▒▒
▒▒v{▒+▒sKs;▒k▒{▒▒cVÃ{▒▒cF▒
s▒3+▒s#▒
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1702I-Z-K9 (PowerPC) processor (revision A0) with 376810K/134656K bytes of memory.
Processor board ID FGL1839XDHS
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.0.72.236
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: F0:7F:06:09:E3:B4
Part Number : 73-16776-01
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC18326WPX
Top Assembly Part Number : 068-05568-01
Top Assembly Serial Number : FGL1839XDHS
Top Revision Number : A0
Product/Model Number : AIR-CAP1702I-Z-K9
% Please define a domain-name first.
ipv6 enable
% Invalid input detected at '^' marker.
ipv6 address autoconfig
ipv6 address dhcp
Press RETURN to get started!
*Mar 1 00:00:13.447: APAVC: Initial WLAN Buffers Given to System is 2500
*Mar 1 00:00:13.495: APAVC: WlanPAKs 42878 RadioPaks 42270
*Mar 1 00:00:13.499: Starting Ethernet promiscuous mode
*Mar 1 00:00:13.503: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar 1 00:00:15.495: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:15.635: %SYS-5-RESTART: System restarted --
Cisco IOS Software, c1700 Software (AP3G2-RCVK9W8-M), Version 15.3(3)JA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 15-Aug-14 12:27 by prod_rel_team
*Mar 1 00:00:15.671: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar 1 00:00:15.679: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
lwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:00:15.819: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:16.667: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:20.459: DPAA Initialization Complete
*Mar 1 00:00:20.459: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar 1 00:00:21.459: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:23.459: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar 1 00:00:24.459: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Mar 1 00:00:27.667: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Mar 1 00:00:28.667: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:28.739: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.10.140, mask 255.255.255.0, hostname APf07f.0609.e3b4
bridge-group 1 source-learning
%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar 1 00:00:34.499: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
%Error opening flash:/capwap-saved-config (No such file or directory)
*Mar 1 00:01:07.519: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
*May 12 12:07:19.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.10.4 peer_port: 5246
*May 12 12:07:25.251: %CDP_PD-4-POWER_OK: 15.4 W power - NEGOTIATED inline power source
*May 12 12:07:27.251: %LINK-5-CHANGED: Interface GigabitEthernet1, changed state to administratively down
*May 12 12:07:48.999: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2214 Max retransmission count reached for Connection 0x5860418!
*May 12 12:08:18.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.10.4:5246
*May 12 12:08:39.999: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
*May 12 12:08:40.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.10.4 peer_port: 5246Peer certificate verification failed FFFFFFFF
*May 12 12:08:40.099: DTLS_CLIENT_ERROR: ../capwap/base_capwap/capwap/base_capwap_wtp_dtls.c:496 Certificate verified failed!
*May 12 12:08:40.099: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 192.168.10.4:5246
*May 12 12:08:40.099: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.10.4:5246
*May 12 12:08:45.791: %CDP_PD-4-POWER_OK: 15.4 W power - NEGOTIATED inline power source
*May 12 12:09:44.999: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
*May 12 12:09:45.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.10.4 peer_port: 5246
*May 12 12:10:14.999: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2214 Max retransmission count reached for Connection 0x58608AC!
*May 12 12:10:44.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.10.4:5246
*May 12 12:11:04.999: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
*May 12 12:11:05.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.10.4 peer_port: 5246
*May 12 12:11:34.999: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2214 Max retransmission count reached for Connection 0x5A70E24!
05-12-2015 03:21 PM
Console into the AP and enter the command: capwap ap controller ip address <Management IP Address of the WLC>
05-12-2015 03:29 PM
APf07f.0609.e304>capwap ap controller ip address 192.168.10.4
Note: the marker is sitting under the first 'a' in capwap
