10-09-2018 09:26 PM - edited 07-05-2021 09:16 AM
I have 4 1815i access points configured as ME capable, all except the one elected as WLC are rebooting randomly, the port on the switch (2960x PoE+) is flapping down and up at the same time the AP will disappear from the list of access points registered on the controller.
AP version (ME 8.8.100), the switch is also upgraded to a recommended version.
Thank you
Elie
10-09-2018 09:47 PM
Can you check the logs from AP console? I want to know the exact error except PoE issue!!!
Dont forget to rate helpful posts
10-09-2018 11:09 PM
10-10-2018 12:31 AM - edited 10-10-2018 12:32 AM
Beginning Release 8.4, Cisco Mobility Express backings up to 100 Access Points. I have bought a Cisco Aironet 1815i WAPs with the Mobility Express option installed. However, it appears that it is still in Lightweight Mode trying to contact a controller (lights burning through every one of the hues). After setting up IP in the CLI, everything proceeded as it should. Another than it, If you're rendering for MS office 365 support then follow the link MS Office 365 Support. You will get an additional help on how to setup MS office.
10-11-2018 03:01 AM
I tried to connect these accesss points to another cisco switch (2960 24-PC-L PoE)
The APs remain up and dont go down and up again as on the other switch, it seems there is a problem with this type of switch.
Is there any compatibility issue with the 1815i access points and the 2960x PoE+ switches ?
Thank you
10-11-2018 03:15 AM
12-05-2018 10:59 AM
I to am having this issue. I have only 5 1815i AP's deployed. The "controller" and another AP that are both plugged into the primary switch (HP 1950-24G POE Switch) are not a problem. My remote AP's are the issue. They are connected to a couple of DELL PowerConnect 5524P switches. Does anyone know if the 1815i will work with the 5524 switches. They seem to work OK when UP but just hang up and restart randomly. All the Ap's are running v8.8.100 firmware.
10-29-2020 07:34 AM
i'm have excactly this trouble too. Should I start a new thread or share here my Console logs?
Thanks in advance!
10-29-2020 08:52 AM
New thread please and also include information like how it's connected, software versions, ...
