aironet 2800 power on 2960
bouchal-38
hello,
when i plug my ap 2800 on my 2960X-FPS-L, i see only 15.4Watts on the 'sho power inline' and on my WLC, how ever, i know that hose AP needs more power, how can i enable the full power(POE+ or 802.3at) on my switch?
there is no way to have the 30W available?
Tx for an answer.
B
Hi @bouchal-38
If the Switch has enough power, unde interface configuration you can choose:
power inline {auto [max max-wattage] | never | static [max max-wattage]}
Try with auto, CDP must negotiate the correct power
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
Leo Laohoo
Post the complete output to the command "sh power inline".
victor.mansson
Make sure CDP enable is set on the switchport and make sure you don't have "no cdp advertise-v2" on the VLAN for the AP.
