07-18-2018 03:01 AM - edited 07-05-2021 08:52 AM
I need to know if i use Aironet Access Point AIR-AP1832I-E-K9 as AP controller can i use AIR-CAP3602i-A-K9 V01 as AP , will both of this device will be compatible to each other so i can control all AIR-CAP3602i-A-K9 V01 from one Aironet Access Point AIR-AP1832I-E-K9 .
Thanks in advance
07-18-2018 05:31 AM
Depends on the version of Mobility Express, but yes. It's possible.
07-18-2018 08:12 AM
thank you for the answer.
can you please let me know which version of mobility express i should use to make compatible
07-18-2018 05:32 PM
Pick any version and then read the Release Notes to see if the model is supported (or not).
