Aironet AP 2802E PoE Issue
i have Cisco Air-AP-2802E-K9 which is connected to 3560G PoE Switch, AP is required 25w but its taking 15.4w, is there any way to push 25w power over 3560G Switch????
or any other solution???
2 Accepted Solutions
Sandeep Choudhary
check if switch can provide 25 w using static method using the command: power inline static
or try with Power injector.....AIR-PWRINJ6=
Dont forget to rate helpful posts
Leo Laohoo
3560G can support up to 15.4 watts.  The only way to provide the adequate power for the AP are:
  • Power Injector; or
  • Power supply
NOTE:  I'm not providing PID for the options because there are ways around getting the right power injectors direct from the manufacturer.
11 Replies 11
scorzalite
i have 3802e  connected to 2960-l  and have the same issue.
the ap's frimware is 8.3.121
Hi All,
For both 2800 and 3800 aps, below is the power requirement. Please make sure these are there in the uplink switches to which these aps are connected.
Sreejith
I downgrade to 8.2.151 ,everything is ok.
Sandeep Choudhary
Catalyst2960-L#show  power inline gigabitEthernet 0/1
Available:120.0(w)  Used:110.8(w)  Remaining:9.2(w)
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Gi0/1     auto   on         30.0    AIR-AP3802I-H-K9    4     30.0
Interface  AdminPowerMax   AdminConsumption
             (Watts)           (Watts)
Gi0/1                 30.0                 30.0
APF80B.CBFD.1542#show cdp entry
  *       All CDP neighbor entries
  device  Name of CDP neighbor entry
APF80B.CBFD.1542#show cdp entry *
<hosts>
<host eth='A0:F8:49:9E:5E:00'
 tag='wired0'
 system_name='Catalyst2960-L'
 system_desc='Cisco IOS Software, C2960L Software (C2960L-UNIVERSALK9-M), Version 15.2(5)E1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Wed 23-Nov-16 00:04 by prod_rel_team'
 port_id='Gi0/1'
 port_desc='GigabitEthernet0/1'
 management_address='10.0.0.247'
 last_rx_ago='17.710000'/>
<host eth='A0:F8:49:9E:5E:01'
 tag='wired0'
 ios_device_id='Catalyst2960-L'
 port_id='GigabitEthernet0/1'
 cdp_capabilities='40'
 ios_version='Cisco IOS Software, C2960L Software (C2960L-UNIVERSALK9-M), Version 15.2(5)E1, RELEASE SOFTWARE (fc1)
 ios_platform='cisco WS-C2960L-16PS-LL'
 cdp_power_mgmt_id='1'
 cdp_power_avail='30000'
 cdp_mgmt_power='4294967295'
 native_vlan='1'
 last_rx_ago='52.410000'/>
</hosts>
APF80B.CBFD.1542#
power inline static command shows only 154000 milli watt max which will become 15.4w i guess
is there any other way without installing power injector???
btw i have 3750 stack wise switch which also give 15.4w output.
If a switch support max 15.4 watt then you cant do anything.
paste the output of the command from switch:
sh power inline
sh cdp neigh
BI-RIY-IN-CSW01#sh power inline
Module   Available     Used     Remaining
          (Watts)     (Watts)    (Watts)
1             n/a        n/a         n/a
2             n/a        n/a         n/a
                            (Watts)
BI-RIY-IN-CSW01#sh cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
BI-RIY-IN-SW03
                 Gig 1/0/21        175              S I   WS-C3560G Gig 0/24
BI-RIY-IN-SW03
                 Gig 2/0/21        175              S I   WS-C3560G Gig 0/23
BI-RIY-IN-SW02
                 Gig 1/0/20        161              S I   WS-C3560G Gig 0/24
BI-RIY-IN-SW02
                 Gig 2/0/20        161              S I   WS-C3560G Gig 0/23
BI-RIY-IN-SW06
                 Gig 1/0/24        134              S I   WS-C3560G Gig 0/24
BI-RIY-IN-SW06
                 Gig 2/0/24        134              S I   WS-C3560G Gig 0/23
BI-RIY-IN-SW05
                 Gig 1/0/23        152              S I   WS-C3560G Gig 0/23
BI-RIY-IN-SW05
                 Gig 2/0/23        152              S I   WS-C3560G Gig 0/24
BI-RIY-IN-SW04
                 Gig 1/0/22        166              S I   WS-C3560G Gig 0/24
BI-RIY-IN-SW04
                 Gig 2/0/22        166              S I   WS-C3560G Gig 0/23
bi-riy-in-ccm01
                 Gig 2/0/17        135               H    VMware    eth0
bi-riy-in-ccm02
                 Gig 1/0/17        166               H    VMware    eth0
SEP0022555FB33E  Gig 2/0/21        129             H P M  IP Phone  Port 1
SEP0022555FB52C  Gig 2/0/24        154             H P M  IP Phone  Port 1
BI-RIY-IN-CUC02  Gig 1/0/17        162               H    VMware    eth0
SEP0022555FB36D  Gig 2/0/24        134             H P M  IP Phone  Port 1
BI-RIY-IN-CUC01  Gig 2/0/17        150               H    VMware    eth0
SEP002290B96B2E  Gig 2/0/24        165             H P M  IP Phone  Port 1
BI-RIY-IN-VGW02
                 Gig 2/0/12        135             R S I  ISR4351/K Gig 0/0/0
BI-RIY-IN-VGW01
                 Gig 1/0/12        164             R S I  ISR4351/K Gig 0/0/0
SEP0022905B2FC5  Gig 2/0/21        146             H P M  IP Phone  Port 1
SEP0022905B4262  Gig 2/0/21        133             H P M  IP Phone  Port 1
BI-RIY-IN-WLC    Gig 2/0/1         147               H    AIR-WLC21 Fastethernet0/0/1
SEP001F9EACC6DE  Gig 2/0/24        171             H P M  IP Phone  Port 1
SEP0022555FBB28  Gig 1/0/23        153             H P M  IP Phone  Port 1
SEP002290BA125E  Gig 2/0/21        133             H P M  IP Phone  Port 1
SEP0024142DD430  Gig 2/0/21        172             H P M  IP Phone  Port 1
SEP0022555FB5AC  Gig 2/0/21        147             H P M  IP Phone  Port 1
SEP002290B96AAB  Gig 2/0/21        169             H P M  IP Phone  Port 1
SEP002290BA1429  Gig 2/0/24        123             H P M  IP Phone  Port 1
SEP002290BA1237  Gig 1/0/23        163             H P M  IP Phone  Port 1
SEPA40CC395543B  Gig 2/0/24        146             H P M  IP Phone  Port 1
SEP002545952288  Gig 1/0/23        136             H P M  IP Phone  Port 1
SEP0022905B4D35  Gig 2/0/24        153             H P M  IP Phone  Port 1
SEPACA0166ECE80  Gig 2/0/21        141             H P M  IP Phone  Port 1
BI-RIY-IN-SW01   Gig 1/0/19        152              S I   WS-C3560G Gig 0/24
BI-RIY-IN-SW01   Gig 2/0/19        152              S I   WS-C3560G Gig 0/23
BI-RIY-IN-CSW01#   conf t
Enter configuration commands, one per line.  End with CNTL/Z.
BI-RIY-IN-CSW01(config)#power inline consumption default ?
  <4000-15400>  milli-watts
BI-RIY-IN-SW06#sh power inline
Available:370.0(w)  Used:63.4(w)  Remaining:306.6(w)
                            (Watts)
Gi0/1     auto   off        0.0     n/a                 n/a   15.4
Gi0/2     auto   off        0.0     n/a                 n/a   15.4
Gi0/3     auto   off        0.0     n/a                 n/a   15.4
Gi0/4     auto   off        0.0     n/a                 n/a   15.4
Gi0/5     auto   on         6.3     IP Phone 7942       2     15.4
Gi0/6     auto   off        0.0     n/a                 n/a   15.4
Gi0/7     auto   on         6.3     IP Phone 7941       2     15.4
Gi0/8     auto   on         6.3     IP Phone 7961       2     15.4
Gi0/9     auto   on         6.3     IP Phone 7961       2     15.4
Gi0/10    auto   on         13.0    IP Phone 8831       3     15.4
Gi0/11    auto   off        0.0     n/a                 n/a   15.4
Gi0/12    auto   on         6.3     IP Phone 7961       2     15.4
Gi0/13    auto   off        0.0     n/a                 n/a   15.4
Gi0/14    auto   on         6.3     IP Phone 7941       2     15.4
Gi0/15    auto   off        0.0     n/a                 n/a   15.4
Gi0/16    auto   off        0.0     n/a                 n/a   15.4
Gi0/17    auto   off        0.0     n/a                 n/a   15.4
Gi0/18    auto   off        0.0     n/a                 n/a   15.4
Gi0/19    auto   off        0.0     n/a                 n/a   15.4
                            (Watts)
Gi0/20    auto   on         6.3     IP Phone 7941       2     15.4
Gi0/21    auto   on         6.3     IP Phone 7942       2     15.4
Gi0/22    auto   off        0.0     n/a                 n/a   15.4
Gi0/23    auto   off        0.0     n/a                 n/a   15.4
Gi0/24    auto   off        0.0     n/a                 n/a   15.4
BI-RIY-IN-SW06#sh cdp neighbors
BI-RIY-IN-WPA1   Gig 0/1           144               T    AIR-LAP12 Gig 0
BI-RIY-IN-WPA3   Gig 0/3           157               T    AIR-LAP12 Gig 0
BI-RIY-IN-WPA2   Gig 0/2           140               T    AIR-LAP12 Gig 0
SEP0022555FB52C  Gig 0/12          134             H P M  IP Phone  Port 1
SEP0022555FB36D  Gig 0/9           173             H P M  IP Phone  Port 1
SEP002290B96B2E  Gig 0/7           145             H P M  IP Phone  Port 1
SEPA8B1D41E746E  Gig 0/5           179             H P M  IP Phone  Port 1
SEP001F9EACC6DE  Gig 0/8           151             H P M  IP Phone  Port 1
SEP002290BA1429  Gig 0/14          163             H P M  IP Phone  Port 1
SEPA40CC395543B  Gig 0/21          126             H P M  IP Phone  Port 1
SEP0022905B4D35  Gig 0/20          133             H P M  IP Phone  Port 1
SEPAC44F2190DBA  Gig 0/10          163              H P   IP Phone  Port 1
BI-RIY-IN-CSW01
                 Gig 0/24          142             R S I  WS-C3750G Gig 1/0/24
BI-RIY-IN-CSW01
                 Gig 0/23          142             R S I  WS-C3750G Gig 2/0/24
BI-RIY-IN-SW06#
Leo Laohoo
  • Power supply
no other choice, installed linksys power injector.
no other choice, installed linksys power injector. thanks
