04-10-2017 01:48 AM - edited 07-05-2021 06:50 AM
Hello
We've been trying to get Aironet 3600's to join our Controller, which they have been once attached. We did a reset on the WLC and initial setup. For some reason the AP's are not joining, even they are requesting IP. I attached each ones configuration files. How to proceed and which things to look at?
Thanks alot!
Saku
Entrepreneur
04-10-2017 04:21 AM
Please post the complete output to the following commands:
04-17-2017 11:32 PM
04-17-2017 11:49 PM
HI,
You are running 7.0.240.0 version on WLC.
3602 series AP require minimum SW version of 7.1.91.0 on WLC to join.
Please upgrade the WLC sw to 7.1.91.0 or higher version and try again.
Here is the compatibility matrix:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Dont forget to rate helpful posts
