All Radio Disabled for AP1252AG
I have 4500-E serial Catalyst Switch and AP1252AG access point.
WS-X4248-RJ45V (48 Port PoE Card) is installed in 4500-E switch and access point is connected with this switch without power injector. But i am getting LOW power error in AP. AP have 3 radios (2.4 GHz). I have tested with 1 radio also but still i have same problem.
Can you please guide me to solve this problem ?
What power command i have to apply on switch port and AP interface.
Its very urgent please...
Prashant Gondaliya
Rob Huffman
Hi Prashant,
From Steve @ Cisco;
Information on the 4500 supporting the 1252 is below:
4500 modules req switch to run 12.2(44)SG or later
WS-X4648-RJ45V-E
WS-X4648-RJ45V+E
power inline port maximum 20000
power inline auto max
From this excellent thread;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=General&topicID=.ee6e8b8&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc1c2b6
Hope this helps!
Rob
Rob Huffman
Hi Prashant,
From Steve @ Cisco;
WS-X4648-RJ45V-E
WS-X4648-RJ45V+E
Hope this helps!
Rob
Dear Rob,
Thanks for immidiate reply. I will make change as per your recommendation.
Prashant
Prashant Gondaliya
Leo Laohoo
If you are running Autonomous image, follow Rob's suggestion. If it's LWAP, then upgrade the controller to the 5.2.X firmware and it will work but with lower power output.
