Alternative to AIR-CAP3702E-E-K9 + AIR-ANT2566D4M-R=
slyfox
Hello Team,
 Because of 'AIR-CAP3702E-E-K9 +  AIR-ANT2566D4M-R=' is not any longer available for the ordering,   what would be the direct alternative to this combination?
Especially in regards to AIR-ANT2566D4M-R=
Leo Laohoo
1562i
@Leo Laohoo unfortunately not certified to be used in Ukraine, it means order processing will stuck at custom clearance level.
Yes it is.
Look at the "Wireless LAN Compliance Lookup".  1562i for Ukraine has a regulatory domain of "-E".  This means it is certified.
Cristian Matei
   The perfect replacement for 3702E access-point would be the 3802E or 3802P access-point. You can keep the current antenna (it fits for 38002P) or order a new one which fits your needs. Take a look in here:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_cisco_aironet_series_2800_3800_access_point_deployment_guide/b_cisco_aironet_series_2800_3800_access_point_deployment_guide_chapter_0100.pdf
Cristian Matei.
