Greetings,
We are happy to announce the first refresh of 8.8MR3 Beta Program for PRODUCTION deployments.
8.8.128.29 is the first, qualified Beta Image and is fully BU supported.
After previous 8.8 CCO, this program is focused on hardening the software quality plus bug fixes mentioned in the release notes. The target date to post 8.8MR3 on CCO is in few weeks.
Release Notes: https://www.cisco.com/web/software/280926587/149893/Release_Notes_8_8_128_29.pdf
Please fill out the signup form for access to the image, within 24hrs you will be granted access.
Signup form à http://cs.co/88MR3InterimAccess
Please login to software.cisco.com with your CCO ID and use the below links to download the software once access is granted.
Cisco 8540 Wireless Controller
Cisco 5520 Wireless Controller
Cisco 3504 Wireless Controller
Cisco Virtual Wireless Controller
Please send in your feedback/issues in the below form.
Feedback form à http://cs.co/88MR3InterimFeedback - We would review the feedback actively and follow up to make sure we address them.
Resolved Caveats
8.8.128.29
CSCvm22760 | dot1x Supplicant config is not removed from Cisco Wave 1 AP after disabled globally on controller |
CSCvm66185 | During AP Boot the AP sends 3 dhcp releases causing BAD_ADDRESS on Windows Server 2016 |
CSCvm68624 | Cisco Wave 1 AP console display logs 'DTX DUMP' |
CSCvm75937 | WLC reloads in TransferTask; flood of "Starting NA Connector" messages |
CSCvn87656 | Cisco Wave 2 APs reloads unexpectedly in the context of vendor driver @ click_packet_type_event_hook |
CSCvo26217 | Fabric Enabled Wireless: Cisco 5520 WLC does not reconnect to CP |
CSCvo35484 | RTS threshold is zero in show CAPWAP client config; excessive RTS sent; client connectivity problems |
CSCvo59784 | AP usage shows discrepancy through pages |
CSCvp00688 | Cisco 2800, 3800 AP radio reloads unexpectedly |
CSCvp01439 | Cisco 1815 AP leaking RLAN VLAN traffic when port looped |
CSCvp25089 | Multicast Traffic stops working when enabling Inline Tagging on CTS with IOS AP |
CSCvp26672 | Cisco 702 APs fail to authenticate clients due to decrypt error on the AP |
CSCvp30608 | Cisco Wave2 AP with data DTLS encryption drop out of order CAPWAP data packets |
CSCvp72309 | Cisco 3800 AP stops passing traffic under client load Intel NIC 8260/8265 load in MU-MIMO deployment |
CSCvp86151 | Cisco Wave1 APs radio reset with code 44, mostly seen on 2.4GHz radio |
CSCvp92098 | Cisco Wireless LAN Controller HTTP Parsing Engine Denial of Service Vulnerability |
CSCvq00695 | 3700 AP does not perform DFS CAC after radio is admin down for over a minute |
CSCvq14112 | 1832 AP showing up as "low power" when using a PWRINJ5 |
CSCvq23385 | Cisco AP reloads unexpectedly on WCPD |
CSCvq26205 | 8.10 (WLC:3504): system reloads unexpectedly with task dx_sync_task |
CSCvq27679 | Radio reset due to pak count mismatch false detection in Cisco 1572AP |
CSCvq59683 | Cisco Wireless LAN Controller Path Traversal Vulnerability |
CSCvq63117 | Client can not send the traffic, when two clients in different VNID joins the network |
CSCvq66030 | Cisco IOS and Cisco IOS XE Software Web UI Cross-Site Request Forgery Vulnerability |
CSCvq66811 | Cisco IOS AP goes out of memory and fails to reply to assoc/reassoc from clients |
CSCvq81315 | AP2700 PCI0 Crash /w Cleanair Enabled |
CSCvq81388 | Wave1 AP resetting 5GHz radio often with radio reset code 44, messages with "DTX marked with poison" |
CSCvq83205 | After AP-SSO failover, WLC fails to send EAPOL M1 |
CSCvq87566 | AP-COS drops client ARP packets with FlexConnect ARP caching disabled |
CSCvr08411 | 2800 ap in WGB mode not able to join 802.1x ssid |
CSCvr28017 | Cisco WLC does not show -A regulatory domain for 5 GHz radio with country code PA (Panama) |
CSCvr33340 | Wave 2 APs in Flexconnect mode sending Auth Request to AAA without Local Auth Enabled |
CSCvr35607 | WLC displays login banner after login, not before login like in older codes |
CSCvr36185 | Cisco 2800 series APs are using 802.11n rates with WPA+TKIP only WLAN |
CSCvr38675 | Client connectivity failure seen after LAN link flap |
CSCvr39587 | MAPs failing mesh_sec_auth and excluding Parent upon RAP failure |
CSCvr47668 | 3504 WLC port 5 not working unless LAG is enabled |
CSCvr75831 | FEW Cisco Wave 1 AP client is loosing connectivity on roaming |
CSCvr82520 | Cisco IOS Software Crashes when configuring a long snmp-server community string |
CSCvr97368 | HTTPS and SSH traffic dead slow with CTS inline tagging enabled |
CSCvs01333 | Cisco Controller sending incorrect certificate password for Cisco FlexConnect local auth EAP-TLS |
CSCvs22835 | Cisco 3600AP: SHA2 MIC certificate failing to join WLC with config ap cert-expiry-ignore mic enable |
CSCvs27550 | Cisco 1815 AP Kernel Panic pointing to Ethernet driver with large size packet traffic |
CSCve64075 | Can't enable https-redirect for Web-auth clients on 1852 ME controller |
CSCvh68195 | 8.8: 5520 Tracebacks observed 0x135956f 0x135af79 0x1362144 0x12ee263 0x3ba6c07dff 0x7f4ede3a439d |
CSCvk66445 | Cisco Wave 2 AP tags UP6 as DSCP63 on the Wired side in CAPWAP header on 8.8MR2 |
CSCvi48253 | Self-signed certificates expire on 00:00 1 Jan 2020 UTC, can't be created after that time |
