Another air18xx fails
David Ritter
Level 4
Level 4
I have another 1852 that fails to connect..  no CDP
However the console stream says:
[*01/13/2022 22:41:04.7685] ACS not enabled
(long wait and reloads..)
U-Boot 2012.07 (btldr release 31) (Jan 07 2021 - 10:12:35)
it does receive an IP and reports its MAC to the switch
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
DRAM: 1 GiB
NAND (ONFI): Detected SPANSION S34MS02G2 [256 MiB]
SF: Detected Macronix MX25U3235F [4 MiB]
MFG data loaded
Scanning shenv data blocks
Total valid parts=4
Active shenv part[0:1], write_counter=14
PCI0 Link Intialized
PCI1 Link Intialized
Net:
PHY ID = 0x4dd074, eth0 found AR8033 PHY
PHY ID = 0x4dd074, eth1 found AR8033 PHY
Valid I2C chip addresses:
AP 1832/1852 detected...
Power Type: 802.3af POE or Others detected...
QCA dump found.
Core 0: Info dump: 0x39013f54:
3f54: 000c0006 00000000 00000000 ed441200 6f720000 00000800 00000030 00000000
3f74: 000c0006 00000000 00000000 ed441100 6e584000 00000800 00000124 00000000
3f94: 000c0006 00000000 00000000 ed441e00 6ec99000 00000800 00000030 00000000
3fb4: 000c0006 00000000 00000000 ed441d00 6ec9e000 00000800 00000030 00000000
3fd4: 000c0006 00000000 00000000 ed441c00 6ec9d000 00000800 00000118 00000000
3ff4: 000c0006 00000000 00000000
Core 1: Info dump: 0x39013f54:
3f54: 3a535953 2d333152 00343152 bed37c10 00014770 3a515249 2d333152 00343152
3f74: c07a0500 c000e2c0 3a514946 2d333152 00343152 00000000 00000000 3a544241
3f94: 2d333152 00343152 c07a050c c000e660 3a444e55 2d333152 00343152 c07a0518
3fb4: c000e4a0 3a435653 2d315220 00343152 fff10000 7ecd561f 00000000 00000001
3fd4: fff10000 007afaa0 00041500 ef4636c0 ed661008 ef41a9a0 00000028 ed42de2c
3ff4: 7eb00000 ed42de10 c001d988
Cleared for a clean reboot ...resetting ...
DRAM: 1 GiB
MFG data loaded
Total valid parts=4
Net:
Valid I2C chip addresses: 51 52
Signature returns 0
BL signing verification success, continue to run...
Auto boot mode, use bootipq directly
Hit ESC key to stop autoboot: 0
Specified BOOT: part2
Booting from part2
Read 1024 bytes from volume part2 to 45000000
Read 26077920 bytes from volume part2 to 45000000
Signature returns 0
Image signing verification success, continue to run...
Using machid 0x1260 from environment
Starting image ...
[01/01/1970 00:00:00.0000] CPU: ARMv7 Processor [512f04d0] revision 0 (ARMv7), cr=10c5387d
[01/01/1970 00:00:00.0000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[01/01/1970 00:00:00.0000] Machine: Cisco Systems 11ac Wave2 Wifi Access Point
[01/01/1970 00:00:00.0000] Memory policy: ECC disabled, Data cache writealloc
[01/01/1970 00:00:00.0000] Kernel command line: ubi.mtd=0 crashkernel=500M-:64M@1280M console=ttyHSL1,9600n8 activepart=part2 activeboot=0 wdgtriggered=0
[01/01/1970 00:00:00.1500] CPU1: Booted secondary processor
[01/01/1970 00:00:00.2200]
[01/01/1970 00:00:00.2200] +++ hydra_ap_gpio_value =3
[01/01/1970 00:00:17.2847] ACPU PVS: 1
[01/01/1970 00:00:19.7040] buginf tty flushing thread started, ttyport=ef5a8a90
[*01/01/1970 00:00:25.9020] buginf() enabled.
[*01/01/1970 00:00:25.9120] Made it into bootsh: Feb 8 2021 22:43:30
[*01/01/1970 00:00:25.9120] bootsh build T-bafe98dab5a999b8bc5f10756127dd817d3843ce-gbafe98da-aut
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
init started: BusyBox v1.23.2 (2021-02-08 22:27:50 PST)
[*01/01/1970 00:00:29.2410] GCM-128 POST passed
[*01/01/1970 00:00:29.2410] GCM-256 POST passed
[*01/01/1970 00:00:29.3810] === 5G radio domain is 41, COPY 5G BDF files from non_ETSI_BDF folder ===
[*01/01/1970 00:00:29.4309] 3
Jan 1 00:00:29 FIPS[1598]: *** shell: FIPS Mode = disabled ***
[*01/01/1970 00:00:29.6609] Active version: 8.5.171.0
[*01/01/1970 00:00:29.6609] Backup version: 8.5.164.0
User Access Verification
Username: [*01/01/1970 00:00:29.8508]
[*01/01/1970 00:00:29.8508] led pattern module start
[*01/01/1970 00:00:29.9008] AP1852I
[*01/01/1970 00:00:30.0008] nss_driver - Turbo Support 1
[*01/01/1970 00:00:30.0008] Supported Frequencies - 110Mhz 550Mhz 733Mhz
[*01/01/1970 00:00:30.0408] NSS firmware booted
[*01/01/1970 00:00:30.0607] NSS firmware booted
[*01/01/1970 00:00:30.1507]
[*01/01/1970 00:00:30.1507] phy_value=0: org="0x1000" phy_reg="0x1800"
[*01/01/1970 00:00:30.5306] Current value of FACTORY_RESET=0
[*01/01/1970 00:00:30.5506] Last reload time: Jan 13 22:41:00 2022
[*01/13/2022 22:41:00.0000] Setting system time Thu Jan 13 22:41:00 UTC 2022
[*01/13/2022 22:41:00.0699] device wired0 entered promiscuous mode
[*01/13/2022 22:41:00.1399] device wired1 entered promiscuous mode
[*01/13/2022 22:41:00.5398] stile module dp init successfully
[*01/13/2022 22:41:00.5398] NBAR Label:BLD_V155_3_S_XE316_THROTTLE_LATEST_20180404_162221 NBAR VERSION:module build date: Feb 8 2021 at 22:41:27
[*01/13/2022 22:41:01.1996] miibus get ef6f7800!
[*01/13/2022 22:41:01.2396]
[*01/13/2022 22:41:01.2396] boot 74352 build T-bafe98dab5a999b8bc5f10756127dd817d3843ce-gbafe98da-aut board corsica mac 2C:0B:E9:BC:10:18
[*01/13/2022 22:41:01.2496] Module: mbedtls .text=0xbf000000 data=0xbf007e18 bss=0xbf008070
[*01/13/2022 22:41:01.2496] Module: aptrace .text=0xbf00c000 data=0xbf018834 bss=0xbf018cc0
[*01/13/2022 22:41:01.2496] Module: led_module .text=0xbf020000 data=0xbf0204e0 bss=0xbf020b48
[*01/13/2022 22:41:01.2496] Module: qca_nss_gmac .text=0xbf024000 data=0xbf02abd4 bss=0xbf02b098
[*01/13/2022 22:41:01.2496] Module: qca_nss_drv .text=0xbf034000 data=0xbf04fb50 bss=0xbf050900
[*01/13/2022 22:41:01.2496] Module: qca_nss_capwapmgr .text=0xbf071000 data=0xbf075ad4 bss=0xbf075c28
[*01/13/2022 22:41:01.2496] Module: nssmgrctl .text=0xbf07c000 data=0xbf07d768 bss=0xbf07da8c
[*01/13/2022 22:41:01.2496] Module: proclikefs .text=0xbf083000 data= bss=0xbf083b40
[*01/13/2022 22:41:01.2496] Module: stile_lm_ft .text= data= bss=
[*01/13/2022 22:41:01.2496] Module: stile_lm_dp .text= data= bss=
[*01/13/2022 22:41:01.2496] Module: ipv6 .text=0xbfa13000 data=0xbfa43fc0 bss=0xbfa4586c
[*01/13/2022 22:41:01.2496] Module: bonding .text=0xbfa5f000 data=0xbfa70640 bss=0xbfa70a6c
[*01/13/2022 22:41:01.2496] Module: lowmemorykiller .text=0xbfa7d000 data=0xbfa7d2c0 bss=0xbfa7d44c
[*01/13/2022 22:41:01.2496] Module: qca_nss_profile_drv .text=0xbfa81000 data=0xbfa82320 bss=0xbfa82494
[*01/13/2022 22:41:01.2496] Module: scsi_wait_scan .text= data= bss=
[*01/13/2022 22:41:01.2496] Module: ssdk_reg .text=0xbfa8b000 data= bss=0xbfa8b838
[*01/13/2022 22:41:01.7095] Last reload reason : 0: unknown
[*01/13/2022 22:41:03.3290] __mm_init_module
[*01/13/2022 22:41:03.3889]
[*01/13/2022 22:41:03.3889] __ol_ath_attach() Allocated scn ed080480
[*01/13/2022 22:41:03.3989] ol_ath_attach interface_id 0
[*01/13/2022 22:41:03.3989] Chip id: 0x9, chip version: 0x1000000
[*01/13/2022 22:41:03.3989] Target Version is 1000000
[*01/13/2022 22:41:03.3989] Flash Download Address c0000
[*01/13/2022 22:41:03.3989] ol_transfer_bin_file: flash data file defined
[*01/13/2022 22:41:03.3989] Cal location [0]: 00000000
[*01/13/2022 22:41:03.3989] Wifi0 NAND FLASH Select OFFSET 0x1000
[*01/13/2022 22:41:03.4189] qc98xx_verify_checksum: flash checksum passed: 0x 2a0
[*01/13/2022 22:41:03.4189] ol_transfer_bin_file 3979: Download Flash data len 12064
[*01/13/2022 22:41:03.4389]
[*01/13/2022 22:41:03.4389] Board data initialized
[*01/13/2022 22:41:03.4889] ol_ath_download_firmware :First OTP download and Execute is good address:0xa000 return param 4660
[*01/13/2022 22:41:03.4889] ol_ath_download_firmware:##Board Id 8 , CHIP Id 1
[*01/13/2022 22:41:03.4889] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS260_negative_pwr_offset_2G_v2_008.bin
[*01/13/2022 22:41:03.5589]
[*01/13/2022 22:41:03.5589] [Flash] : Ignore Module param
[*01/13/2022 22:41:03.5589] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*01/13/2022 22:41:03.5889] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin
[*01/13/2022 22:41:04.6885] HTC Rx: insufficient length, got:4 expected =8
[*01/13/2022 22:41:04.6885] Startup Mode-0 set
[*01/13/2022 22:41:04.6885] HTC Service:0x0300 ep:1 TX flow control disabled
[*01/13/2022 22:41:04.6885] HTC Service:0x0100 ep:2 TX flow control disabled
[*01/13/2022 22:41:04.6885] Firmware_Build_Number:70
[*01/13/2022 22:41:04.6885] num_rf_chain:0x00000004 ht_cap_info:0x0000185b vht_cap_info:0x339a79b2 vht_supp_mcs:0x0000ffaa
[*01/13/2022 22:41:04.6885] RES CFG Support wmi_service_bitmap 9778
[*01/13/2022 22:41:04.6885] Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 50 to TGT
[*01/13/2022 22:41:04.6885] ol_ath_service_ready_event: sw_cal_support_check_flag: 1
[*01/13/2022 22:41:04.7685] wmi_ready_event_rx: WMI UNIFIED READY event
[*01/13/2022 22:41:04.7685] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FRAG_DESC_BANK_CFG sent to FW for radio ID = 0
6 Replies 6
ammahend
can you share switch  port config where AP is connected ?
-hope this helps-
interface GigabitEthernet1/0/4
switchport access vlan 125
switchport mode access
switchport voice vlan 131
switchport port-security maximum 5
switchport port-security violation restrict
switchport port-security aging time 2
switchport port-security aging type inactivity
spanning-tree portfast
spanning-tree bpduguard enable
ip device tracking maximum 10
to start with can you simply put this config on the port and bounce it once, make sure cdp is running, make sure port is not in error disabled state.
default interface gig1/0/4
shut
no shut
I am assuming you have a local SVI for vlan 125 and you have helper address configured.
-hope this helps-
patoberli
Is this a new AP or a used one? I tend to say a radio is broken, because it can't apply the firmware to the radio and also because there are QCA core dumps.
If you're lucky, it's just a broken firmware image. You could fix that by going into rommon and deleting the primary image. But I would try this as a last resort.
I would try rommon but the language changed and I don't have the command set..
Rich R
