Antenna AIR-ANT2451NV-R for Aironet 1262N AP
Hello everybody,
I want to use the AP on a little office and I think this antenna give a good performance,
what do you think?, any recommendation is accepted
Best Regards
2 Accepted Solutions
Scott Fella
That should be fine for your 1262.
-Scott
Well the client suggest the equipment
Heard of this line before.
What I did was put in a document the cost of the 1262 + the antenna vs the cost of an 1142.  I presented it to the client and asked them, "are you sure you really, really want the 1262".  There was a loooooooooooong silence.  And the client choose the 1142.
7 Replies 7
Scott Fella
-Scott
Leo Laohoo
Agree.  Should be fine.
Just how do you plan to install the antenna?  Ceiling?  Wall?
Please elaborate.
Hello, thanks for the comments.
On the Ceiling Panel 3 meters above the floor.
First AP coverage Area:
The coverages area is a rectangle 9 x 24 meters, with no more than 10 concurent users per area.
Second AP coverage Area:
The coverages area is a square 10 x 10 meters, with no more than 10 concurent users per area.
Best Regards
Sounds good.  You've obviously done your homework.
Question, if this is an office, why use a 1262?  I mean you can choose 1040 or 1140 and the cost is far less.
Well the client suggest the equipment, but I think the AP1142 can do the job very well. Just I need to consider put the AP1142 on the wall instead ceiling.
Best Regards
nice view point.
Thanks for the analogy.
Best Regards
