05-02-2015 11:07 AM - edited 07-05-2021 03:07 AM
I am trying to access my company`s files remotely from my samsung galaxy tab running on android. I have connected to the server using anyconnect, but have no idea how to actually access the files on the server. I am connected to the server, now what?
05-04-2015 04:20 AM
Refer the anycoonect Client ( android ) manual
http://www.cisco.com/c/en/us/td/docs/security/vpn_client/anyconnect/anyconnect30/user/xmart/b_Android_User_Guide/b_Android_User_Guide_chapter_01.html#reference_9D90FB411DD046B2BEA8CC7ACE787A91
06-24-2015 12:34 AM
check the below similar post
https://supportforums.cisco.com/discussion/11515931/cisco-vpn-anyconnect-android-tablets-or-android-phones-sprint-network
06-29-2015 03:36 AM
Cisco recommends the AVF AnyConnect client for unsupported devices running Android 4.0 or later. Supported devices should use the brand-specific AnyConnect client regardless of the version of the Android operating system.
![]() Note | AnyConnect for Android is available for download only from the Android Market. You cannot download it from the Cisco website or after connecting to a secure gateway. |
| Step 1 | Determine if your device is one of the supported devices and install the appropriate brand-specific AnyConnect package.
Cisco provides brand-specific AnyConnect packages that offer full-featured VPN connections for these devices. These brand-specific AnyConnect clients are provided in partnership with the device vendors and are the preferred AnyConnect clients for supported devices.
| Step 2 | Determine if your device is running Android 4.0 (Ice Cream Sandwich) or later to install AnyConnect ICS+.
This AnyConnect client offers VPN connectivity supported by the Android VPN Framework (AVF) in Android 4.0 or later. AVF provides only basic VPN connectivity. The AnyConnect AVF client, dependent upon these basic VPN capabilities, is unable to provide the full set of VPN features available in the brand-specific packages. |
| Step 1 | Tap the AnyConnect Icon to start the AnyConnect app. |
| Step 2 | If this is the first time that you are starting AnyConnect after installing or upgrading, accept the displayed End User License Agreement to continue. |
| Step 3 | Tap Add New VPN Connection to configure a connection entry. See Adding Connection Entries Manually for details. |
| Step 4 | (Optional)Tap Menu and choose:
