AP 1131 AG + a cable modem
sudip.acharya1
Beginner
Beginner
I am trying to use my AP with my cable modem. I have upgraded to the proper ios but am still running to a issue. Ideally, I want the AP connected to the cable modem and client would connect to the AP, get an IP and be able to surf the web. Right now, the ap is the only device that gets an IP from the modem (Moto sb5120). How can I enable: (1) the AP to act as a dhcp server and (2) forward web traffic to the modem?
Here is the conf. from the AP. I erased the changes I made during testing. Any help will be appreciated.
c1130-k9w7-mx.124-10b.JDA/c1130-k9w7-mx.124-10b.JDA
Cisco IOS Software, C1130 Software (C1130-K9W7-M), Version 12.4(10b)JDA
cisco AIR-LAP1131AG-A-K9
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 $1$Z7vP$0TTz8a2ezkxhzmxkHsSyt/
no aaa new-model
power inline negotiation prestandard source
username Cisco password 7 123A0C041104
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
sclements
Contributor
Contributor
Hiya! All Cisco Access Points are bridges, meaning that they simply pass IP traffic from one interface to the other without intervening. It sounds like you're looking for the functionality of a router (to do address translation & DHCP services). These are not part of a 'bridging only' solution.
Thats what I figured so i put a linksys wired router between the AP and the modem. Now, when i have one wireless client and one or more wired client in the linksys, i cant get on the web.
Destination unreachable.
The AP is a bridge, which means you have to setup DHCP server on the Linksys. Most Cable service providers only allow one IP address to be assigned behind the modem, so thats why. Check the number of DHCP clients you can assign on the linksys.
sudip.acharya1
Beginner
Beginner
I got it to a point where it works. But, when I connect the laptop to the wifi, the connection drops after a couple of minutes. I have tried multiple laptops.
The only way to get it back is to power cycle the cable modem and the AP.
