AP 1140 conifguration for a survey
atefbmejri
I am all new to this. I have a stand alone 1140 AP and i am trying to perform a site survey using the AP; However I dont know what configs need to be on the AP for the survey ? can you help me please?
5 Replies 5
Stephen Rodriguez
all you need is a very basic config.  Just be sure to set the power to half what the client can support.
dot11 ssid Survey
   authentication open
   authentication key-management wpa version 2
   wpa-psk ascii 0 Survey1234
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid Survey
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Thank you for your quick answer.
Both Radios need to be on? Radio0 and Radion1 which one is the 2.4 and 5 ghz?
It depends.  If you are only looking for 2.4GHz, then no.  But if you want 5GHz coverage as well, then yes.
Radio0 is the 2.4
Radio1 is the 5
HTH,
Steve
HTH,
Steve
This What I have on the AP right now.
the ssid "Survey" needs to be brodcasted for the Survey? if so how can i set ip up on th eAP?
no aaa new-model
dot11 syslog
dot11 ssid Survey
   authentication open
username Cisco password 7 05280F1C2243
bridge irb
no ip address
no ip route-cache
ssid Survey
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid Survey
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
under the SSID add the command guest-mode.  that will broadcast the SSID.  Don't forget to add in your wpa key as well
HTH,
Steve
HTH,
Steve
