AP 1200 with static WEP and EAP
hogoqo
I have 1200 APs running 2 SSIDs. One SSID is using EAP and the 2nd SSID is using static WEP. Before i enaqbled WEP everything seemed to be running Okay. With WEP enabled i am kind of getting mixed results. One thing i have noticed i am getting a lot of CRC Errors and Header CRC Errors. I am also getting a lot of Output Transmit errors. I am running ver 12.2(15) on APs and using 802.11abg cards. On my Ethernet side i am getting throttle errors.
Any ideas or help will be appreciated.
QH
gamccall
Level 4
Level 4
Are the SSIDs associated with different VLANs, and if so, is your upstream switchport configured properly for trunking those VLANs to the AP? What you describe sounds like it might be a trunking problem.
No trunks or VLANs configured at all.
