ap 1230 ios upgrade problem
giga01
I have 30 ap 1230 in my network with ios version 12.3(4). I use cisco client e not cisco client with leap and peap authentication and all work fine.
I have upgrade one access point 1230 to ios 12.3(8) and all my clients are ko.they not receive any wireless signal and are blocked. There is a problem in new ios ?
thanks for reply
Rob Huffman
Hi Giga01,
Not sure the exact ios version you went to (12.3.(8)JA or JEA or just 12.3(8), but I think that a bug related to this ios brings up the AP with the radios disabled.
CSCsc79121 Radio interfaces are not operational after an upgrade.
CSCsd84198 802.11b radios are not operational after an upgrade.
Hope this helps!
Rob
Please remember to rate helpful posts.....
Is there a fix for this then
Derek
