AP 1252 radio 802.11a is not supported on WLC 4402
rezende.c
Hi All,
   I running a WLC with 4.2.0.5 software and AIR-LAP1252AG-T-K9 access points.
   After register in WLC the 802.11a radio not working and is showing as "not supported".
   What can be happing? My WLC is configured to use "US" contry code.
help please,
Claudio Rezende
Rasika Nayanajith
Your WLC is in regulatory domain North Amerca (-A), but your AP suppose to be in South America  or APAC (-T for Brazil or Thaiwan).
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps5861/product_data_sheet0900aecd80537b6a_ps6087_Products_Data_Sheet.html
If it is on same regulatory domain, you can configur multiple countries on your WLC (in case you have AP in different countries within same region).
Also 1252 to work you should have min 4.2.61.0 sotware version of your WLC (refer table 5 )
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
Rasika
**** Pls rate all useful responses****
Ok about regulatory domain. I will check this.
About second link, I'm using WLC 4402 with 4.2.205.0 software, not WLC 5500.
Claudio
Ok, then your software is supported this AP model.Given link is not specific to particular WLC hardware(5508)  & it is applicable to all WLC/AP in general.
As long as you get compatible regulatory domain AP, things should work.
Rasika
**** Pls rate all useful responses ****
