AP 1572EAC is fail to join with WLC 2504
riyazpatel424
I am trying to register AP 1572EAC with WLC 2504, but it is not join. When i tried to ping wlc from AP, it can reachable.
8 Replies 8
Which WLC version?
Which is the AP country code?
Make sure date and time is correct.
Make sure you have license.
-If I helped you somehow, please, rate it as useful.-
##-WLC version is 7.5.102.0
Country code is +91
Date and time both WLC nd AP are same.
License also available-##
Thanks & regards,
Riyaz Patel
1572EAC AP need minimum SW version on WLC is 8.0.135.0. So you must upgrade the WLC software first and then try again.
Here is the comptibility matrix:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Dont forget to rate helpful posts
Sandeep Choudhary
If its the first mesh access-point you are adding on your WLC, you need to explicit allow those type of access-points to join the WLC. You can do this by adding the AP MAC address under "Security" -> "AAA" -> "AP Policies" > Add(1572 Ethernet MAC address)
Then your AP will register to WLC, once registered, you can change AP  mode to Local.
Dontf orget to rate helpful posts
Cisco Aironet 1572eac outdoor access point is supported with WLC version 8.2.166 ??
YES  it support 8.2.166.0 version on WLC.
Thank you Sir.
It's helpful for this case, thank you!
