elena.vispe95
Beginner
AP 1830: conversion from CAPWAP to Mobility Express
I am trying to convert  AP1832 from CAPWAP version to a Mobility Express. I have the new software in a TFTP server, but when I console to the AP I can´t type  AP#ap-type mobility-express tftp because it seems to be in a romon state.
When it starts up, I have to hit ESC because if not it reeboots:
U-Boot 2012.07 (btldr release 21) (Aug 19 2015 - 10:57:19)
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
DRAM: 1 GiB
NAND (ONFI): Detected SPANSION S34MS02G1 [256 MiB]
SF: Detected Macronix MX25U3235F [4 MiB]
MFG data loaded
Scanning shenv data blocks
Total valid parts=4
Active shenv part[1:0], write_counter=3
PCI0 Link Intialized
PCI1 Link Intialized
Net:
PHY ID = 0x4dd074, eth0 found AR8033 PHY
PHY ID = 0x4dd074, eth1 found AR8033 PHY
Valid I2C chip addresses: 51 52
GPIO 7: Pull High detected...
Power Type: 802.3af POE or Others detected...
Image start 0x45000000 size 0x00138000
Key start 0x45138000 size 0x00000230
Sinature start 0x45138230 size 0x00000180
Signature returns 0
BL signing verification success, continue to run...
Auto boot mode, use bootipq directly
Hit ESC key to stop autoboot: 0
(RNAQ-C7) #
I have downloaded the software with tftpboot comand:
(RNAQ-C7) # tftpboot
Full duplex link
Port:2 speed 100Mbps
Using eth0 device
TFTP from server 192.168.1.254; our IP address is 192.168.1.1
Filename 'part.bin'.
Load address: 0x44000000
Loading: #################################################################
(ouput omited)
done
Bytes transferred = 35316935 (21ae4c7 hex)
(RNAQ-C7) #
The problem is that I don´t know how to boot the AP with the new software, because I can type only this commands:
(RNAQ-C7) # ?
? - alias for 'help'
base - print or set address offset
bootipq - bootipq from flash device
chpart - change active partition
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
echo - echo args to console
env - environment handling commands
ethreg - ethreg - Switch/PHY Reg rd/wr utility
exit - exit script
false - do nothing, unsuccessfully
go - start application at address 'addr'
help - print command description/usage
i2c - I2C sub-system
iminfo - print header information for application image
imxtract- extract a part of a multi-image
ipq_nand- Switch between SBL and Linux kernel page layout.
loadb - load binary file over serial line (kermit mode)
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
md - memory display
mm - memory modify (auto-incrementing address)
mtdparts- define flash/nand partitions
mtest - simple RAM read/write test
mw - memory write (fill)
nand - NAND sub-system
nm - memory modify (constant address)
pci - list and access PCI Configuration Space
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
printmfgenv- Print manufacture information data
printshenv- printshenv- print shared environment variables
reset - Perform RESET of the CPU
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
saveshenv- saveshenv - save shared environment variables to persistent storage
setenv - set environment variables
setshenv- setshenv - set shared environment variables
sf - SPI flash sub-system
showvar - print local hushshell variables
smeminfo- print SMEM FLASH information
source - run script from memory
test - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
true - do nothing, successfully
ubi - ubi commands
usb - USB sub-system
verify_bl- Cisco Bootloader signature verify
verify_lx- Cisco Image signature verify
version - print monitor, compiler and linker version
(RNAQ-C7) #
Any kind of help will be appreciate.
Thanks in Advanced for your help.
7 REPLIES 7
mohanak
What is the version of capwap running on 1830?
Hello mohanak,
It does not support sh version command:
(RNAQ-C7) #sh version
## Error: "version" not defined
(RNAQ-C7) # sh
HUSH_VERSION=0.01
In the start up process, I could see this information about version:
User Access Verification
Username: [*08/27/2015 15:57:41.1999] copy part1_info.ver to CAPWAP_VERSION.
[*08/27/2015 15:57:41.2099] part2_info.ver does not exist. CAPWAP_BAK_VERSION is 0.0.0þ
Thanks for your help
Alexey Satimov
Beginner
I had similar prolem with customer's new AP1832. Nothing is help to convert from CAPWAP to ME edition.
So you need put part.bin (it archived in ap1g4) to tftp server and type command boot bootipq tftp
Please be shure you in one subnet with AP and your tftp server is 192.168.1.254.
     Where would I find the part.bin file? You mention it is in th ap1g4 file but that file is a .FILE type.
Riccardo
I know that this discussion is old, but I just had the same problem, the part.bin file is obtained by decompressing the .tar image (I used AIR-AP1830-K9-8-3-141-0.tar) that you download from Cisco.com.
Regards.
Umer Javed
Beginner
Did you solve your this problem, if yes, please sharing your solution with me is highly appreciated.
Thanks.
Have you tried the steps available on the below link?.
Hope this will help you convert the image.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_Cisco_Mobility_Express_Deployment_Guide/b_Cisco_Mobility_Express_Deployment_Guide_chapter_010.html
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Content for Community-Ad
