01-15-2016 12:08 AM - edited 07-05-2021 04:29 AM
Hi guys,
Do somebody knows if new AP1832 with AireOS 8.2 is supported under Flexconnect mode in WLC 2504?
I have some doubts as for Flexconnect Matrix Nov 2015 (http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/112042-technote-wlc-00.html), the new 1832 and 1852 does not appear but in Datasheets of 1832, it says something different.
We have to get some 200 APs for Flexconnect but I don't know if they're supported or not.
Regards..
Solved! Go to Solution.
01-18-2016 09:33 AM
Correct, FlexConnect is not supported in the 1832 yet.
From the 8.2 WLC release notes (http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn82.html)
01-15-2016 12:47 AM
The 2504 can support a maximum of 50 access points from memory, so you wont be able to attach 200. You'll need to go to a 5508.
It looks to me like the 1832 has been supported since 8.1.120 on the 2504.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn81mr2.html
01-15-2016 03:27 AM
Correct, but 2504 is our guy as we're going to deploy 5 of them in HA, is the customer requirement.
The problem is running in Flexconect mode as it seems not to be supported yet in 1832.
01-18-2016 09:33 AM
