05-19-2025 08:01 AM
I just got a 1852 AP on my network replacing a 1602i. Sonos speakers worked before now only one works. I also have a CS200-50 switch.
How do I configure the AP and switch to get it to work?1852
05-19-2025 08:06 AM
@trha You question is very vague.... you said you replacing the 1602i with a 1852, so did you also change your switch? I would think that you would just configure the 1852 as close as you can with the 1602. If other things have changed, then that is difficult for folks here to help you with. Have you tried to search the wireless forum as many in the past have had issues with the sonos and mDNS. You should start there and tinker around first to gather more data.
05-19-2025 08:52 AM
It is only the AP that is replaced. Switch is the same with the same config.
I have tried playing with mDNS, Global Multicast but it dosent work
