AP C1832I not JOIN WLC 2504
gtstech
I have a WLC 2504 running version 8.5.182 and AP C1832I also the same version WLC but I have a problem AP cannot join WLC 2504. Please help me.
7486.0B58.5868#[*12/10/2024 10:21:42.0000] can't find the Ip from discoveryRequest array
[*12/10/2024 10:21:42.0000] CAPWAP State: DTLS Setup
[*12/10/2024 10:21:42.2099] Allowing expired MIC certificate
[*12/10/2024 10:21:42.2099] Certificate Start Date: Jan 7 16:34:11 2014 GMT
[*12/10/2024 10:21:42.2099] Certificate End Date: Jan 7 16:44:11 2024 GMTem
[*12/10/2024 10:21:42.2099] CAPWAP State: Join
[*12/10/2024 10:21:42.2099] Sending Join request to 192.168.3.2 through port 5248
[*12/10/2024 10:21:42.2199] Join Response from 192.168.3.2
[*12/10/2024 10:21:42.3299]
[*12/10/2024 10:21:42.3299] CAPWAP State: Image Data
[*12/10/2024 10:21:42.3799] do NO_UPGRADE, part1 is active part
[*12/10/2024 10:21:42.3799] CAPWAP State: Configure
[*12/10/2024 10:21:42.3799] DOT11_CFG[0] Radio Mode is changed from Local to Local
[*12/10/2024 10:21:42.3799] DOT11_CFG[1] Radio Mode is changed from Local to Local
[*12/10/2024 10:21:45.2190] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/10/2024 10:21:48.0681] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/10/2024 10:21:50.9172] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/10/2024 10:21:53.7763] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/10/2024 10:21:56.6254] Re-Tx Count=5, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/10/2024 10:21:59.4745] Re-Tx Count=6, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/10/2024 10:21:59.4745] Max retransmission count exceeded, going back to DISCOVER mode.
[*12/10/2024 10:21:59.4845] GOING BACK TO DISCOVER MODE
[*12/10/2024 10:21:59.4845] CAPWAP State: DTLS Teardown
[*12/10/2024 10:22:04.3430]
[*12/10/2024 10:22:04.3430] CAPWAP State: Discovery
[*12/10/2024 10:22:04.3430] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*12/10/2024 10:22:04.3430] Discovery Response from 192.168.3.2
7 Replies 7
@gtstech
This seems to be the problem
Run the command
config ap cert-expiry-ignore mic enable
You already allow expire cert.
But you have max retransmit' check country code of AP
https://blog.router-switch.com/2013/11/a-solution-for-2504-wlc-configuration-to-different-regions-of-aps/
MHM
How to know which country the AP is in?
marce1000
  - I would also suggest to try : config ap cert-expiry-ignore ssc enable   (so in the end use both commands including)
   If that does not help then disable NTP on the controlller and set the clock back in time.
  M.
gtstech
I tried but the problem still happens.
Leo Laohoo
What is the serial number of the AP?
Rich R
What do the AP join stats on the WLC show?
Make sure you're using the latest code version 8.5.182.12 on the WLC (link below)
