AP not connect to WISM
CSCO11191613
i configured wism to support(cisco AIR-AP1231G-A-K9,cisco AIR-LAP1252AG-A-K9) in one buliding in my enviroment .
now i put all AP in vlan 220 , wireless users in Vlan 192 as our standard
the probelm  1231 AP take IP from DHCP pool and working fine
but 1252 not take IP from wism.
please help me
9 Replies 9
Surendra BG
Where is the POOL for both 1231 and 1252??
Surendra
Surendra BG
on Cisco Core 6513 in DHCP Pool in vlan 220 (AP Mangement)
and All interfaces for vlan are UP
If a 1252 that is on the same switch and same vlan as a 1230 and is not getting an ip address, this is very suspicious.
Please post the configuration of your DHCP pool (configured option 60 by any chance ?) and switchports.
Please also check the console of a 1252 booting.
Hope this helps.
Nicolas
don't forget to rate answers that you find useful
CSCO11191613
ip dhcp pool Mang_AP
network 10.1xx.220.0 255.255.254.0
   default-router 10.1xx.220.10
   option 43 hex ********************
   option 60 ascii "Cisco AP c1250"
==>Now All 1230 AP in vlan 220 and working fine
but i have problem in 1252 AP in vlan 220 not getting IP form DHCP in VLAN 220
regards
If you put 2 different AP models (1230 and 1250) in the same subnet, you need to remove option 60.
As far as I'm concerned, I consider the option 60 totally useless.
Hope this helps:
Nicolas
Don't forget to rate answers that you find useful
Leo Laohoo
1230 work but not the 1250.
Let me ask the basic question:  What is the firmware of the WiSM?
CSCO11191613
thanks for all
Software Version6.0.182.0
after remove option 60 from DHCP still  the problem !!!!!!!!!!!!!!!!!!!!!!
this is from wism (sh wism status)
     WLAN
Slot  Controller  Service IP       Management IP    SW Version  Status
9     1           10.1xx.219.251   10.1xx.220.251   6.0.182.0   Oper-Up
9     2           10.1xx.219.252   10.1xx.220.252   6.0.182.0   Oper-Up
thnaks again
Please mark the Question as Answered if the provided information is correct and issue is fixed.
thanks,
Vinay
Thanks & Regards
Leo Laohoo
Console into the 1250 AP and then reboot this AP.  Post everything starting from the bootup up.
