AP not join Controller after upgrade
ntlong3
Frequent Visitor
Frequent Visitor
I have C9800-L-C
Access Point 1832 2802 9115
After Upgrade Controller from 17.3.4 to 17.9.5, AP not join Controller and version AP is 17.8.0
I downgraded to 17.6.6 but AP still won't join.
Last disconnect reason in 9800 is AP auth Failure
Console AP show no valid user found, please config from controller
I created a user on the controller, but in 17.3.4 I left it blank.
Please help me
10 Replies 10
Mark Elsen
  - Have a checkup of the controller's configuration using the CLI command show tech wireless
     and feed the output from that into Wireless Config Analyzer
 - Debug the AP join process on  using https://logadvisor.cisco.com/logadvisor/wireless/9800/9800APJoin
 - Post the complete boot process of one of these APs
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Leo Laohoo
Console into the AP and reboot.
Post the entire boot-up process of the AP.
ntlong3
Frequent Visitor
Frequent Visitor
Hi Leo,
I send log 2802
                        >... AP boot log provided
    + Check if the wireless controller has a valid NTP server configured (and usable = show ntp assoc)
    + Check if the wireless controller has (still) sufficient licenses to accommodate all APs
    + On the AP execute this command : show version
                                                             show ip int brief
   + Check wired connection on a problematic AP on a particular switch (port-connection) ;
      issue the command  : show cdp neighbors detail
                                        verify duplex and speed (acquired) settings
  M.
        - Another thing I am observing from the boot log (2802.txt) is that there seems to be an ongoing cycle to find a controller; is the
  intended DNS entry for CISCO-CAPWAP-CONTROLLER.xangdau.petrolimex.com.vn still correct , I also see Discovery Response from a 10.x address which is different apparently , are there some NAT solution implemented in the networking ?
 M.
And what firmware is the 2800 on?
Rasika Nayanajith
Do you have a back up of your WLC configuration prior to upgrade ? Then I would check any configurations have been changed since upgrde.
Are these Mesh mode or Local mode  APs? If mesh mode please check those AP Ethernet MAC addresses added to WLC (Configuration > AAA > AAA Advanced > Device Authentication)
Rasika
*** Pls rate all useful responses ***
debug capwap packet <<- share this from WLC 9800
MHM
Rich R
@ntlong3 check your WLC config using the Config Analyzer (link below) as Marce has already advised.
Use "sh wireless stats ap join summary" on the WLC to see what reason the WLC is giving for the join failure?
What is the correct IP address for the WLC? (123.30.16.153, 10.0.11.200 or 10.0.11.10?)
Not according to the log you provided which says "Active version: 17.3.4.40" which is probably the version they were running before you did the upgrade.
Have you tried doing a factory default reset on the APs?
Also take note of Field Notice: FN74109 - Access Point Image Corruption During CAPWAP Upgrade May Result in Boot Failure - Software Upgrade Recommended - Cisco and Recover from a Boot Loop Caused by Image Corruption on Wave 2 and 11ax Access Points (CSCvx32806) - Cisco
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
ntlong3
Frequent Visitor
Frequent Visitor
Hello, thanks for everyone's help.
I resolved the issue by disable Authorize AP against in AP Policy.
Once again, thank you for everyone's help.
