AP not joining WLC...
ljustl
Hello all,
Working on wireless, CAPWAP is initiated, however AP cannot be joined or discovered by WLC..
using 3700 AP and 2504 WLC
Show run and outputs are attached. (for core, access sw, WLC and AP)
CAPWAP State: Join
Finding DTLS connection to delete for AP (192:1xx:xxx:xx/xxxxx)
Disconnecting DTLS Capwap-Ctrl session 0x17aa3ba8 for AP (192:1xx:xxx:xx/xxxxx)
CAPWAP State: Dtls tear down  acDtlsPlumbControlPlaneKeys: lrad:192.1xx.xxx.xx(xxxxx) mwar:192.1xx.xxx.x(xxxx)
DTLS keys for Control Plane deleted successfully for AP 192.xxx.xxx.xx
DTLS connection closed event receivedserver (192.xxx.xxx.x/xxxx) client (192.1xx.xxx.x/xxxxx)
Entry exists for AP (192.1xx.xxx.xx/xxxxx) apModel: AIR-AP3702I-UXK9  apType = 41 apModel: AIR-AP3702I-UXK9
I need help!!!!
43 Replies 43
C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
3560 doesn't support TDR so you'll need to find alternative method of testing the cable.
Can you post the complete output to the switch command "sh interface <AP PORT>"?
here you go
access#show int fa0/45
FastEthernet0/45 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0019.2f0c.e0b1 (bia 0019.2f0c.e0b1)
Description: AP1
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:02:32, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
7303 packets input, 1775091 bytes, 0 no buffer
Received 1607 broadcasts (864 multicasts)
1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 864 multicast, 0 pause input
10886 packets output, 1341552 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
port is going between IEEE PD and AP
Not a cable fault.
Power down the AP for about 5 seconds and power back up.
Jul 17 23:45:58.980: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to down
Jul 17 23:45:59.978: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to down
Jul 17 23:46:02.696: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to up
Jul 17 23:46:03.703: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to up
Jul 17 23:46:49.236: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to down
Jul 17 23:46:50.234: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to down
Jul 17 23:46:52.868: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to up
Jul 17 23:46:53.875: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to up
Jul 17 23:47:35.575: %IP-4-DUPADDR: Duplicate address 192.168.175.2 on Vlan175, sourced by 404e.361f.c7b7
Jul 17 23:48:33.741: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to down
Jul 17 23:48:34.739: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to down
Jul 17 23:48:37.340: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to up
Jul 17 23:48:38.347: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to up
Jul 17 23:48:55.602: %IP-4-DUPADDR: Duplicate address 192.168.150.2 on Vlan150, sourced by 404e.361f.c7b7
Jul 17 23:50:22.835: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to down
Jul 17 23:50:23.833: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to down
Jul 17 23:50:26.509: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to up
Jul 17 23:50:27.516: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to up
Jul 17 23:52:02.039: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to down
Jul 17 23:52:03.037: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to down
Jul 17 23:52:05.713: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to up
Jul 17 23:52:06.720: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to up
as you see above, it's going up and down in couple seconds...
I will power down the AP and power back up. brb
Can you change the cable?
believe it or not, it's up.
do you have clue why this is happening? or maybe i need to unplug and plug when i notice this?
My other question is...
Does AP needs to be online? or it's okay as long as they are broadcasting SSID?
because none of this equipment are connected to the internet
When I try with an app, it says Wi-Fi not connected. and leads to the page wit h"login error, the internet connection appears to be offline." i've attached.
Yes, I've seen this before.  It's a known bug.
I do not understand the question.
Does AP needs to be connected to the internet?
Please take a look at the attachment, that is the outcome from an app.
I can't configure universal AP through an app.
as soon as unplugged and plugged in...
access#
Jul 17 23:54:07.683: %ILPOWER-5-IEEE_DISCONNECT: Interface Fa0/45: PD removed
Jul 17 23:54:08.329: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to down
Jul 17 23:54:09.327: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to down
Jul 17 23:54:19.822: %ILPOWER-7-DETECT: Interface Fa0/45: Power Device detected: IEEE PD
Jul 17 23:54:25.442: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to up
Jul 17 23:54:26.449: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to up
access#sho power inline fastEthernet 0/45
Interface Admin Oper Power Device Class Max
(Watts)
Fa0/45 auto on 15.4 Ieee PD 4 15.4
access#
*Mar 1 03:39:03.757: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to down
*Mar 1 03:39:04.755: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to down
*Mar 1 03:39:07.431: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to up
*Mar 1 03:39:08.438: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to up
*Mar 1 03:40:56.902: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to down
*Mar 1 03:40:57.900: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to down
*Mar 1 03:41:00.493: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to up
*Mar 1 03:41:01.499: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to up
*Mar 1 03:41:50.220: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to down
*Mar 1 03:41:51.218: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to down
*Mar 1 03:41:53.811: %LINK-3-UPDOWN: Interface FastEthernet0/45, changed state to up
*Mar 1 03:41:54.817: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/45, changed state to up
another question,
Im at the link you shared with me "
Universal AP Regulatory Domain Deployment Guide"
i tried shut, no shut, power inline never and auto, swap different cables and others more.
Have any clue? i'm using
"C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)"
Thanks...
For a 3700 AP, what would be the CLI commands to show joined (or attempted) WLC state and what SSID the AP is broadcasting?
Ive tried the suggested 'debug capwap' commands but the syntax doesnt match a 3700
take a look at from_ap txt, it's from today
AP_message is from July 8.
