AP not joint dtls error
Ramprasad2
hi team
i have wlc 2500 and running IOS ( 8.1.102.0 )
i have ap 3602i
but not join ap with wlc even i have runn below command
1 (Cisco Controller) >config ap dtls-wlc-mic sha2 ( its taken )
(Cisco Controller) >config ap cert-expiry-ignore mic enable
Incorrect usage. Use the '?' or <TAB> key to list
Even erro showing below
*Jan 1 00:34:40.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.31.33.250:5246
*Jan 1 00:34:40.999: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
*Jan 1 00:34:41.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.31.33.250 peer_port: 5246
*Jan 1 00:35:10.999: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2214 Max retransmission count reached for Connection 0x7346F84!
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Jan 1 00:35:40.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.31.33.250:5246
*Jan 1 00:36:08.999: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
*Jan 1 00:35:51.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.31.33.250 peer_port: 5246
*Jan 1 00:35:51.011: %PKI-3-CERTIFICATE_INVALID_NOT_YET_VALID: Certificate chain validation has failed. The certificate (SN: 5832A5BA00000002C661) is not yet valid Validity period starts on 03:37:53 UTC Aug 31 2015Peer certificate verification failed 001A
*Jan 1 00:35:51.011: DTLS_CLIENT_ERROR: ../capwap/base_capwap/capwap/base_capwap_wtp_dtls.c:497 Certificate verified failed!
*Jan 1 00:35:51.015: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 172.31.33.250:5246
*Jan 1 00:35:51.015: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.31.33.250:5246
how to fix it
2 Accepted Solutions
Mark Elsen
   - Ref : https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html
                >....(Cisco Controller) >config ap cert-expiry-ignore mic enable
      - You need 8.3.x or above to be able to use that command , also consider : https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
Look at the time and date of the AP.
Please post the complete output to the following commands:
  1. WLC:  sh sysinfo
  2. WLC:  sh time
  3. AP:  sh version
balaji.bandi
check the valid certs and also check the below FN :
BB
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Leo Laohoo
  1. WLC:  sh sysinfo
  2. WLC:  sh time
  3. AP:  sh version
Rich R
Read all the field notices below ...
