AP OEAP600 not work in Wireless LAN Controller HA Mode AP SSO
jsfsantos
Beginner
Beginner
Hello Guys,
I had a problem with deploy using Wireless LAn Controller in HA mode AP SSO to works with AP OEAP 600. Its not work properly. I check that access point get to register in controller and propagate the SSID but I can not connect. In the Deployment Guide AP SSO configuration says the this AP is not support. Anybody has new about this case or workaround?
João Ferreira
Rasika Nayanajith
VIP Mentor VIP Mentor
VIP Mentor
If deployment guide says it is not supported then there is no option unless new firmware releases addressing this.
Check with Cisco about upcoming 8.0 code address this. (if it is not there in 7.6.x train)
Another alternative is use a normal AP converted as OEAP to see if it is working. Here is how you can convert normal AP as OEAP (I have used 7.0.x code & feature FlexConnect was know an H-REAP)
http://mrncciew.com/2013/01/15/configuring-oeap/
Rasika
*** Pls rate all useful responses ****
Recognize Your Peers
