AP on a stick Site survey with 1832/1852/2802/3802
kopur1991
Has anyone done AP on a stick sitesurvey with the AP's in the title.
After i configure the ME AP and plug it to my site survey kit it dosent broadcast any ssid, i have confirmed that this is not POE issue.
And the error i am getting on the console is : Config not syned to APs since no AP is present.
The AP i am currently using is 2802e.
So my question is: has anyone done AP on a stick sitesurvey with success, if so how ?
Ric Beeching
Level 7
Level 7
What software version? This thread from December is quite extensive and sounds like you are encountering the same issue:
https://supportforums.cisco.com/discussion/13178716/meconfig-not-synced-aps-no-ap-present-bugcscva60696
Ric
Please rate helpful / correct posts
Hi Ric,
I am using 8.3.111.0.
Yes... it may affect multiple versions.
Have you tried the solution outlined in the thread? particularly the one by Michael.Provost.
Ric
Yes and that worked while the AP was connected to the switch.
But when the ap is connected to the sitesurvey kit that soulution does not work. We dont have switch on our kit.
