06-17-2020 02:06 AM - edited 07-05-2021 12:11 PM
Can AP selfcheck is it broadcasting Wifi signal or not? if not - reboot
I had a few situation with stuck AP.
Solved! Go to Solution.
06-17-2020 02:49 AM
- It's a bit of a wrong question, correctly configured AP, determines a valid operating state, including providing SSID's albeit broadcasting or not. If that does not happen, items to look into is checking the configuration. If it get's stuck then look into possible software bugs and or try the latest software version available (for example). If the term 'stuck' for instance correlates to a hardware problem , then your suggestion may not be possible either. If it keeps happening with specific or determined AP's then they should be replaced.
M.
06-17-2020 02:49 AM
M.
