10-27-2006 01:04 PM - edited 07-03-2021 01:09 PM
Hi, anyone can help on this ?
I power cycle my Cisco Access Point (Aironet 1200 series) connected thru console cable to my PC.
On Hyperterminal, I notice that after certain initialization outputs the startup process 'freezes' always at the same point. I already did power cycle the device multiple times, no improvement.
I use my console cable and PC to successfully manage other devices, therefore I am ruling out that as being the problem.
Any ideas why this is happening to my access point and how can I fix it ?
Please find next message with attached screenshot of hyperterminal captured at the moment where the output from the startup 'freezes'.
10-29-2006 10:01 PM
It may be a problem related to the image. Did u try to reset the AP to factory Defaults by harware reset.
Naveen b
01-05-2007 08:26 AM
This has worked for me with APs and switches who did same thing - unplugged and replug the serial plug on the back of your computer.
Don't ask my why it works, it just did.
01-05-2007 11:33 AM
Verify that your handshake / flow control setting in HyperTerminalis set to "None" (no hardware, no software ... nothing)
Good Luck
Scott
04-10-2009 08:58 AM
Great that worked for me, thanks !!! 5 points
