03-07-2011 12:59 AM - edited 07-03-2021 07:55 PM
Hello-
Appreciate your assistance with the selection of antenna for AIR-AP1252AG-E-K9.
It will be installed in a big warehouse: 50 meters in length, 20 meters in width and 5 meters in height. I doubt we can mount it on ceiling, but on the wall only. Availability of 5GHz is not mandatory.
I was reading about AIR-ANT2451NV-R -- would it be OK if we go ahead with this antenna?
Thank you in advance.
03-07-2011 05:41 AM
Well actually, is it the antenna you are planning to mount on the wall ? Because that antenna is omnidirectionnal so made for ceiling placement usually.
On a wall, you can hardly radiate backwards (since it's attached on a wall).
03-07-2011 03:13 PM
2.4 Ghz only? How about this:
Cisco Aironet 2.4-GHz MIMO 6-dBi Patch Antenna (AIR-ANT2460NP-R)
