09-26-2016 08:09 PM - edited 07-05-2021 05:53 AM
Hi Expert,
I have a problem to join AP1523E to WLC2504.
I already configure the WLC and put the MAC filtering list of AP's.
For the Switch, I already configured
How to know the AP status will join the WLC?
I see the AP light always blinking green colour.
Please help me.
Thanks.
Hanif Saharudin
Solved! Go to Solution.
09-26-2016 08:19 PM
The first thing I typically do is stage the mesh AP's. I would connect the APs to the same subnet as the WLC and let the AP's join and download the image. Then you can place the RAP in whatever subnet you want and the RAPs then can be disconnected from the wired network to validate that the maps join the raps.
-Scott
09-26-2016 08:39 PM
09-26-2016 08:43 PM
The AP needs to get a dhcp address. If the AP and he WLC is on the same subnet, the the AP would do a later 2 broadcast to discover the AP. You are using the AP Ethernet mac in the filter?
-Scott
09-26-2016 08:51 PM
09-26-2016 08:48 PM
Try to add a -E country code since your controller has only Malaysia.
-Scott
09-26-2016 09:03 PM
Hi Scott,
This -E country code need to add at AP or WLC?
My access point is AP-CAP1532E-C-K9.
Thanks.
Hanif Saharudin
09-26-2016 09:06 PM
If the -C is Malasia then you are good. Place the AP on the same vlan as the WLC management interface. Make sure there is a dhcp server also so that the ap can get an ip or else it will never join.
-Scott
09-27-2016 12:06 AM
Hi Scott,
I already configure at DHCP server, MAC filter, and AP is the same VLAN as per WLC management interface.
Kindly have look at attachment files for the clear view of my problems.
Is it this issue can cause from switch configuration?
Thanks and Regards,
Hanif Saharudin
