04-20-2018 06:43 AM - edited 07-05-2021 08:32 AM
Hi All,
I would like to know how to connect antenna in Cisco AP1562E. I have only two antenna, if I connect the antenna one on slot 1 & next on slot 3, will this work . I am not looking for beamforming, I just want wireless coverage
Nikhil
04-20-2018 06:14 PM
Look at THIS. It's either the two antennas are attached on top or the bottom. One on top and one on the bottom isn't recommended.
04-20-2018 08:38 PM - edited 04-20-2018 08:41 PM
Hi Leo,
But the doc says, doesn't this mean the AP can provide signal from single port
The Aironet 1562E access points are equipped with four separate N-type female connectors that carry dual-band signals or, through software control, can be configured such that the bottom pair of connectors carry only 2.4-GHz signals and the top pair carry only 5-GHz signals. This gives users multiple configuration options, as shown in Figure 1.
Nikhil
04-20-2018 08:56 PM
