ap1810w connect wire client issue.
Rps-Cheers
VIP Collaborator VIP Collaborator
VIP Collaborator
Hi Everybody. I have some AP1810w that is flexconnect mode ap,every AP1810w's LAN2 or LAN3 connect a PC,but,sometimes PC ping other devices' ip address ,the ping packets cannot bigger than 1472 Bytes,sometimes the ping packets also can bigger than 1472 Bytes,even the packets 10000 Bytes also normal.I don't know what wrong about it. WLC: WLC5520 software version:8.2.166
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
RichardAtkin
Participant
Participant
Have you tried a later WLC release, like the most recent 8.3 or 8.5 releases?
If you connect directly the the switch's switchport instead of going via the AP, does the experience differ at all?
Hi RichardAskin; not yet,i didn't upgrade.Is there any wireless issue influence the PC when it connect ap1810w by wire?Whether there is a ap issue. I will make a PC connect switch,to prove it difference from connect to ap.
HI Richard;
I have test that PC connect directly the the switch's switchport,and it's normal,only PC connect to AP1810w LAN port will occur this issue.When the issue occur,wireless clients don't influence.
Recognize Your Peers
