04-25-2013 12:29 AM - edited 07-03-2021 11:58 PM
Hello another question, can i mangane a AP in 7.4 with a WLC in 7.0.2.2?
This situation will be temporarly, time to upgrade my other WLC, i need to move them from 1 to another...
Tx for an answer.
B
04-25-2013 05:05 AM
If the AP is supported, then yes. If the AP doesn't support the code, then no. See the compatibility list here.http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html#wp78157Sent from Cisco Technical Support iPhone App
Log in to Community
