APs 1852 not join after WLC restart.
thbinhvdc
I use Cisco Wireless LAN Controller 2504 and AP 1852.
I config AP joined to Wireless LAN Controller 2504. If Wireless LAN Controller reboot, AP not re-join to Cisco 2504.
Please help me fix this problem.
Many thanks.
Regards.
Just as suspected. The WLC isn't configured with NTP. This is why every time the WLC reboots the AP won't join until the correct time and date is configured.
7 Replies 7
Leo Laohoo
That sounds like NTP is not configured on the WLC.  Post the complete output to the following commands:
1. WLC: sh sysinfo;
2. WLC: sh time; and
3. AP: sh version
thbinhvdc
Dear Sir/Madam
I provide info:
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Build Info....................................... Engineering Special
Product Version.................................. 8.5.140.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
OUI File Last Update Time........................ Sun Sep 07 10:44:07 IST
2014
Build Type....................................... DATA + WPS
System Name...................................... neolab-wlc
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 172.16.4.2
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 2 days 0 hrs 37 mins 32
secs
--More or (q)uit current module or to abort
System Timezone Location......................... (GMT +7:00) Saigon, Hanoi,
Bangkok, Jakatar
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... Multiple Countries :
CN,HK,VN
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +34 C
External Temperature............................. +39 C
Fan Status....................................... 4400 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 45
OUI Classification Failure Count................. 206
Memory Current Usage............................. 34
Memory Average Usage............................. 34
CPU Current Usage................................ 0
CPU Average Usage................................ 0
Flash Type....................................... Compact Flash Card
Flash Size....................................... 1073741824
Burned-in MAC Address............................ 64:D8:14:DB:65:C0
Maximum number of APs supported.................. 75
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
show time
Time............................................. Mon Jul 22 13:29:26 2019
Timezone delta................................... 0:0
Timezone location................................ (GMT +7:00) Saigon, Hanoi,
Bangkok, Jakatar
NTP Servers
NTP Version.................................. 3
NTP Polling Interval......................... 86400
Index NTP Key Index NTP Server
Status NTP Msg Auth Status
Please help me
Rgds
Tran Hoa Binh
1. You need to configure a reachable NTP server with valid time.
2. Check if your WLC requires a FUS upgrade (I would say yes): https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/fus-rn-20.html
paste the complete bootup process from AP console.
Dear Sir/Madam
I cleared config and reboot AP.
I will schedule to reboot WLC at this weekend and inform later.
I very thanks for your reply.
Best regards
Tran Hoa Binh (Mr)
Thank you very much.
