06-24-2013 03:49 AM - edited 07-04-2021 12:16 AM
Are Cisco 1130ag APs compatibale with Cisco Virtual Wireless LAN Controller?
Solved! Go to Solution.
06-24-2013 04:42 AM
It is.. AP compatibility depends in the code that is running on the WLC. Here is a matrix that is a good reference.
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
06-24-2013 04:42 AM
06-24-2013 04:55 AM
I have 3.x code running on my 1131ag AP. Any idea how I could upgrade it to 7.x?
06-24-2013 05:34 AM
The ap gets its code from the WLC. So when the ap joins the WLC, the WLC will push the correct image to the access point.
06-24-2013 05:51 AM
