Ascom Wifi IP Phones with Cisco 4400 WLAN Controllers
Anvar Mohammed
hi,
i have 2 4400 WLAN Controllers in same Network , but Ascom IP Phones which is associated to theses defferent Controllers can reach via Network and can ring the phones but not able here the voice while they are associated to deffrent WLCs. There is no issues if both Phones are assoicated to same WLC.
any body can suggest me what will be the problem with this????
thanks,
Anvar
9 Replies 9
Stephen Rodriguez
Anvar,
     When the phones are on the same WLC the callers can hear each other, but when they are on different WLC they can't?
Are the phones in the same subnet on both WLC?  What version of code is on the WLC?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Hi sir,
phones are in the same subnet , also both WLC are in the same subnet, also phones are ringing even at deffrent WLCs, but only problem can't talk each other.
firmware version of both WLCs are 7.0
thanks,
Anvar
ok, and they are in the same mobility group?
7.0.98.0, 7.0.116.0, 7.0.220.0, or 7.0.230.0?
can you post the show wlan < wlan ID of the phones > from both controllers?
Steve
HTH,
Steve
sir,
  both codes are 7.0.166.0
  and both are in the same mobility group
plase find below output of show wlan command
Controller-1
(Cisco Controller) >show wlan 3
WLAN Identifier.................................. 3
Profile Name..................................... Voice-Vlan-Ground Floor
Network Name (SSID).............................. Minhalvoice
Status........................................... Enabled
MAC Filtering.................................... Enabled
Broadcast SSID................................... Disabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 4
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Disabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ voicevlan-gr
Multicast Interface.............................. Not Configured
--More-- or (q)uit
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Platinum (voice)
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... 802.11g only
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
--More-- or (q)uit
   Accounting.................................... Global Servers
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Disabled
   H-REAP Local Authentication................... Disabled
   H-REAP Learn IP Address....................... Enabled
   Client MFP.................................... Optional but inactive (WPA2 not configured)
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
--More-- or (q)uit
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
Controller-2
Number of Active Clients......................... 15
--More-- or (q)uit
Radius Servers
--More-- or (q)uit
Security
   IP Security................................... Disabled
   IP Security Passthru.......................... Disabled
--More-- or (q)uit
ok, that looks ok with one exception.  There is no wired protocol.  Can you go check the QoS profiles and the Platinum, and check to see if the wired protocol is set to 802.1p?
You'll also want to make sure that the LAN supports the QoS.  WLC trunk should be mls qos trust cos, the AP should be mls qos trust dscp, and all the switch uplinks should be mls qos trust dscp as well.
Steve
HTH,
Steve
Hi steve,   i have a small correction .... First controller is 4402 and other is 5508. can this be the issue . am doing the steps as per your suggestion.
thanks,
Anvar
the controller type shoudln't matter for this type of issue.
Steve
HTH,
Steve
sir,
i did it all your suggested but still the issue is there. do we need to try something more ???
Anvar
