08-21-2012 11:32 PM - edited 07-03-2021 10:33 PM
Hi all,
One of my customer place they want strong authencation for anroid mobiles also. Where apple phones supports WPA2-enterprise, they already using mac based authentication.
Thanks in advance.
08-22-2012 03:58 AM
I don't really understand your question. You say the apple devices are using wpa2-enterprise, so why not have the android use the same.
08-22-2012 04:29 AM
You can use
WPA2-enterprise is supported oinS and Android.
ent from Cisco Technical Support iPad App
08-27-2012 06:38 AM
Most wireless clients out on the market today support either WPA version 1 + TKIP or WPA version 2+ AES
WPA version 2 + AES is the most secure option to use + 802.1x using an external radius server for authentication or the local option on the WLC.
Also if you want to use N support then you need to stick with WPA version 2 + AES as the encryption since only this encryption supports N speeds.
