Authentication PEAP issue (I believe!).
andrea.meconi
Level 2
Level 2
I'm using PEAP, AP1200, ACS 3.2, WXP SP2 and Microsoft AD to authenticate machine and user. The authentication process supplies the WEP key to the client.
When I'using a Cisco 350 client adapter all works fine. When I'm using another adapter, the ap log shows a continuous association/deasso.
Any ideas?
Thanks.
Andrea.
john.preves
Level 4
Level 4
are you using the client software for the wireless or windows. One or the other must be disabled.
Start/settings/ control panel/Administrative tools/ Services/ Windows Zero configuration/disable...
Many thanks for your help.
I'm using only WZC on a fresh WXP installation.
Now I'm testing without vlans and seems ok!
Andrea.
