Instead of statically assigning a vlan to a switch port where the AP is connected, is there a way to use 802.1x or NAC to assign the right vlan to an AP itself (not the clients)?
You should be able to do this if you setup switchport authentication on the switch the AP is connecting to and have the IETF attribuiles 64, 65, and 82 passed down from the Radius server.
