Autonomous 2602i Won't Negotiate 1000BASE-T
Mike Hendriks1
I have a pair of 2602is running in autonomous mode.  One of them refuses to negotiate or form a link at gigabit speeds on its wired port.  The other one performs fine.  I have swapped the physical location of the two APs, confirming that the problem follows the AP, ruling out any of the intermediate infrastructure.  I have tried both 'speed auto' and 'duplex auto' as well as 'speed 1000' and 'duplex full.'  In both cases, the output of 'show interfaces GigabitEthernet0' shows 'Full Duplex, 100Mbps, media type is T.'  Has anyone encountered this before?
See below for more:
Working AP:
ap1#show run int gi0
Building configuration...
Current configuration : 159 bytes
interface GigabitEthernet0
 no ip address
 duplex auto
 speed auto
 bridge-group 1
 bridge-group 1 spanning-disabled
 no bridge-group 1 source-learning
end
ap1#show int gi0
GigabitEthernet0 is up, line protocol is up
  Hardware is PowerPC Ethernet, address is xxxx.xxxx.xxxx (bia xxxx.xxxx.xxxx)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is T
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output never, output hang never
  Input queue: 0/18174/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 9000 bits/sec, 14 packets/sec
  5 minute output rate 2000 bits/sec, 2 packets/sec
     14672368 packets input, 1507277654 bytes, 0 no buffer
     Received 5685838 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     7821057 packets output, 81120759 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
ap1#
Problem AP:
ap2#show run int gi0
 no ip address
 duplex auto
 speed auto
 bridge-group 1
end
ap2#show int gi0
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  5 minute input rate 8000 bits/sec, 11 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
     1930374 packets input, 353697824 bytes, 0 no buffer
     Received 1873017 broadcasts (0 IP multicasts)
     103129 packets output, 17340778 bytes, 0 underruns
ap2#
And if that doesn't help, RMA them, you have 10 years of hardware warranty.
marce1000
 - Have a factory defaults reset on the problematic AP and try again.
   M.
I had considered that as an option.  Thanks!
I've tried that too.  No change in the symptom
