Autonomous Wireless AP LED turn on off on specific time
Gabor Torok
Is it possible Autonomous AP LED turn on off on specific time ?! I mean e.g. scripting it because in the night it's disturbing, but on daytime it's good to see status.
LED dimming is doesn't work for some reason only full bright (maybe a bug ?) IOS 15.2
Cheers
Sandeep Choudhary
As per my knowledge, there is no way to do it for specific time.
Dont forget to rate helpful posts
Sandeep Choudhary
So it's no possibility of event scripting?!
If you are good with scripting then ofcourse you can do it.
