Basic Encryption For Aironet 1100
shoesbologna
Community Member
Have a 1100 AP, and am using the gui to configure it.
I know that I want to use mac authentication, but I also want to use some type of encryption. I’ve been messing with it for the last 3 days now, and can’t seem to find a solution as to what I can do.
Can someone please post a config that would give me basic 128 encryption, which could be used by most of my clients? I’d also like this config to require the use of it.
kecampbe
Level 2
Level 2
These instructions assume that you are starting from factory defaults.
STEP 1: Select madatory WEP encryption and set a 128-bit key in encryption key 1. Your clients will need to match this information. They will need a 128-bit key in the same slot.
Security >> Encryption Manager
- Encryption Modes section
-- Choose "WEP Encryption" and select "Mandatory"
- Encryption Keys section
-- Set Transmit Key to Encryption Key 1
-- Encryption Key 1: 12345678901234567890123456
-- Encryption Key 1 Key Size: 128 bit
- Click Apply
STEP 2: Setup a SSID.
Security >> SSID Manager
- Current SSID List (delete the default SSID, and create your own)
- Current SSID List:
- SSID: my-ssid
- Authentication Settings:
-- Select "Open Authentication"
--- NOTE: You can come back later and enable MAC authentication. Keep it simple the first time through and don't use MAC authentication.
--- NOTE: All other settings on this page should be at factory defaults.
- Click Apply
The following is the CLI equivalent of the instructions:
interface Dot11Radio0
encryption key 1 size 128bit 12345678901234567890123456 transmit-key
encryption mode wep mandatory
ssid my-ssid
authentication open
The following is the full config of my Dot11Radio0 interface from my show run:
no ip address
no ip route-cache
encryption key 1 size 128bit 7 1823F25A0AB8494E9154647CF72C transmit-key
ssid my-ssid
authentication open
short-slot-time
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
I hope this helps.
Kent.
kecampbe
Level 2
Level 2
- Click Apply
- SSID: my-ssid
- Click Apply
ssid my-ssid
authentication open
no ip address
no ip route-cache
ssid my-ssid
authentication open
short-slot-time
station-role root
no cdp enable
bridge-group 1
I hope this helps.
Kent.
Kent,
Thanks for the help, that's exactly what I needed.
I was also wondering about WPA. I've been reading a lot about it, and was able to get it to work on some of the computers. But on some it didn't work.
Here's what I did.
- Selected TKIP+WEP128
- Selected my SSID
- went about half way down the page and selected mandatory.
- checked wpa
- entered a ascii password.
Then I went to my clients and tried to connect (after I entered their mac into the local mac table) using the ascii password that I created. Entered it twice ~ and some of them would work and some of them wouldn't. I know that there are some requirements for running WPA, and I'm also pretty sure that I can configure to use wpa and if that doesn't work, to just use the static wep that I've configured. Is this correct? and if so, can you point me in the right direction for exactly how to do this?
Thanks in advance for all of the help.
Anybody Help?
