06-02-2016 06:32 AM - edited 07-05-2021 05:10 AM
I have two WLC 2504 one as Active and the other are HA .so the installation will be N+1 .and also we have to switches 4500 using HSRP between them .
i need what is the recommended design for connect both WLC to the Two cores .
is the attached diagram will be recommended in case of Active Core Fail or Active WLC fail .
06-02-2016 09:55 PM
Yes,that set up will work
Rasika
06-02-2016 10:02 PM
I agree with Rasika. I don't do sso, and have our hospital designed this way and we have 7 wireless distort, 25k clients and have zero issues.
06-05-2016 03:08 AM
Dear Rasika ,
Thank you , Could you please tell me what the design of the first core is active for some vlan and the second core is active for some vlan .
06-05-2016 09:25 PM
I would not allocate vlan in that way. I would keep one 4500 as HSRP active for all the vlans and keep other one as standby. That makes things simple when it comes to troubleshooting.
Rasika
