Between Hreap AP and Local Ap Rooming
Hi ,
I was using Local AP with 60 ap connected WLC 4404. But I set hreap ap one of them  because speedtest of 1140 ap  is very low . (4 Mbbps)
than I had done hreap mode . speedtest increase to 60 Mbps . but  when   7921 ip phone room between hreap and local  ap , pacet loss is done .
How can I sokve this problem
Scott Fella
You shouldn't mix.  If that location is remote and h-reap fixes your issue with speed, then change the APs to h-reap and also create an h-reap group and place APs in that group. There is a limit to 25 APs in an h-reap group also. So if you have to create more than one, you might have roaming issues between h-reap groups. So place APs in groups that are near each other.  If the APs are local to the WLC then local mode should be used and maybe figure out why local mode is slower as it shouldn't be like that.
-Scott
-Scott
Philip91
Which type if encryption are you using ?
WPA2 PSK
WP2 Enterprise // EAP ?
Greetings
Philip
WP2 Enterprise
