Block communication between different WLANS
Ramon1980
Community Member
We have on our network 2 different wlans. One is called "work" and the other is called "guest". Both have different interfaces connected to them. I can login to "work" and have a different ip address as that of "guest", so far so good. What i want to do now is that when im on the "work" ssid i cannot connect to "guest" and vica-versa.
Whenever i do a ping now from "work" to "guest" it goes through and i want to block this.
Can anyone tell me how to do this? (We have a cisco 2500 series wireless controller)
Ramon
Mark Elsen
  - Normally this kind of separation will be kind of a default result because standard practice is to terminate the SSIDs/WLANs on separate VLANS/subnets , if then routing is correct such as guest(vlan) only allowing Internet access you will (already) have what you want,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rich R
You say you get different IP addresses - do you mean in a different subnet?
If so, then I assume you already have the WLANs connected to different VLANs.
But if you have (for example) a router terminating both those VLANs and routing between them then obviously you have connectivity.
You can use ACLs and/or firewall to keep those VLANs separate.  It really depends how you have your network setup.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
