11-09-2023 10:24 AM
Hola necesito crear un nuevo SSID que solo permita el acceso a una URL especifica y bloquee todo lo demás, probé varias alternativas pero no logro conseguirlo.
Hello, I need to create a new SSID that only allows access to a specific URL and blocks everything else, I tried several alternatives but I can't get it.
- Chasis WLC 5508
- AP flexconnect
11-09-2023 11:28 PM
- Use an external firewall , an wireless controller only provides 'simple' access through wireless and is not designed for that ,
M.
11-10-2023 05:46 AM
Like Marce says that is not a WLC function - basically what you're asking for is content filtering.
If you really want to do something like that on the WLC you could try using an ACL:
If the domain has a known, fixed IP address (these days many web IPs change all the time in the cloud) then you could create an ACL which only allows DHCP, DNS and access to that IP address. If the IP changes then your ACL will need to be updated.
11-10-2023 06:05 AM
URL based ACL for filtering was introduced in 5520 and 8540 from version 8.4, however it is not supported on old controller models including 5508.
11-10-2023 07:45 AM
Which is why I suggested that an IP based ACL would be needed <smile>
