10-14-2016 07:14 AM - edited 07-05-2021 05:58 AM
Hi all,
I have a challenge and I can't find the correct answer to it, not even from TAC, so here I am.
Task:
I want to be able to get an alert via NMS of a rogue AP advertising my SSID's
Rogue AP ---> broadcasting my ssid1, my ssid2 ---> WLC 2504 (Soft V 8.1.102) send alert ----> NMS ---> generate email
I've created a Rogue Rule under security, rogue rules a condition with the following
Type: Malicious
Notify: ALL
State: Alert
This part is working great, the NMS is getting the alerts from the controller when I bring up a rogue AP and start broadcasting my ssids.
Issue:
The NMS is getting tons of useless information, including rogue AP's which is expected since the location is sharing offices with other tenants.
I want the WLC to only send the rule I've configured and nothing else. I have tried to play with SNMP Trap Controls in the WLC with no success.
Thanks in advance for your input.
Solved! Go to Solution.
10-14-2016 03:23 PM
not even from TAC
TAC is most likely going to point you into the direction of Cisco Prime Infrastructure. There is a trial/evaluation license available for use.
10-14-2016 03:23 PM
not even from TAC
